Likes Likes:  1
Results 1 to 10 of 29
Thread: Starting issue
    Regular Member Anth1718's Avatar
    Jan 2016
    Newcastle
    Vehicle : Vectra c
    Trim : Sri
    Engine : 1.8
    Year : 55
    Smile Starting issue
    Can anybody help with a strange starting issue 1.8 pre vvt full canbus.
    Just started today on the way to work
    Starter fine took out of garage stoped to lock garage.
    Went to start and the was a second delay
    Drove fine and I stoped at junction I turned off and took 3 attempts to start.
    Got to work and tried 3 or for times no start then it was fine for 3 or 4 tries.
    When it won’t start all dash lights are normal but nothing on starter.
    When it starts it’s normal and sounds normal.
    Strangely it popped up on screen a warning for indicator bulbs all on near side.
    This happened a week ago and went off
    Don’t know if the 2 issues are related
    please see photo for codes I’ve just pulled
    Full Member Jon1796's Avatar
    Sep 2015
    Norwich
    11 Post(s)
    Vehicle : Vectra VXR x2
    Trim : VXR
    Engine : 28NEH
    Year : 07
    Mileage : 74,600
    Could be a few things ecu on the way out, do a live data run see what you get. But your bcm not programmed correctly, and bulb on the way out, uhp god knows can be temper mental.
    ​​​VECTRA VXR‘s BOTH TEAPOT TUNED WITH A LITTLE OLD DOGGIE TWEAK.
    TECH2WIN AND GDS2 2021 DIAGNOSTICS.
    PIN RETRIEVAL FROM SOME MODULES.
    Jan 2016
    Newcastle
    Vehicle : Vectra c
    Trim : Sri
    Engine : 1.8
    Year : 55
    Quote Originally Posted by Jon1796 View Post
    I should have said I know what the uhp is and that’s fine I know that the 02 is a cheap sensor the rest I’m not sure.
    im not sure what you mean about bcm not programmed correctly.
    im unable to get anything from live data as it’s an intermittent fault I couldn’t get it to fault while plugged in
    Regular Member petrolcan's Avatar
    Dec 2015
    Watford
    20 Post(s)
    Trim : Elegance
    Engine : 1.9 CDTI (120)
    Check your earth strap from the battery is making good contact.
    Jan 2016
    Newcastle
    Vehicle : Vectra c
    Trim : Sri
    Engine : 1.8
    Year : 55
    Quote Originally Posted by petrolcan View Post
    I was looking at the earth wires yesterday and they all look good on the battery
    trying to locate the earths is a bit of a pain.
    looks like there’s
    1 from battery to suspension turret
    1 from battery Over the back of engine I assume goes to starter
    or around that location
    1 goes down around sub frame I assume to alternator or steering pump.
    am I correct anymore I’ve missed?
    I was thinking of taking them all off cleaning and a bit copper grease can’t do any harm
    Sep 2015
    Norwich
    11 Post(s)
    Trim : VXR
    Engine : 28NEH
    Year : 07
    Mileage : 74,600
    Quote Originally Posted by Anth1718 View Post
    https://www.vectra-c.com/forum/showt...ifier-recieved
    Nov 2013
    suffolk
    Vehicle : vectra 2007
    Trim : sri
    Engine : z18xer
    As with all computers, often an unplug & reset is all that is needed. (battery disconnect)
    Leave it a few hours to allow capacitors to drain their voltage.
    Often a fix!
    Jan 2016
    Newcastle
    Vehicle : Vectra c
    Trim : Sri
    Engine : 1.8
    Year : 55
    I don’t have this fault code ?
    Sep 2015
    Norwich
    11 Post(s)
    Trim : VXR
    Engine : 28NEH
    Year : 07
    Mileage : 74,600
    same thing not coded properly.
    wrong environment.
    Jan 2016
    Newcastle
    Vehicle : Vectra c
    Trim : Sri
    Engine : 1.8
    Year : 55
    wrong environment.
    What the key not programmed in or failing?
    everything has been coded in and worked fine for the last 3 or 4 years I’ve owned the car
  1. Starting issue
    By Montgomery_lfc in forum Vectra C / Signum Troubleshooting
    Last Post: 20th February 2014, 11:30
  2. HELP!!! some Q's about starting issue
    By small in forum Vectra C / Signum Troubleshooting
    Last Post: 11th January 2013, 21:16
  3. 2.2 dti sri starting issue
    By sjs in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2010, 23:42
  4. Starting Issue please help
    By stevelee in forum Vectra C / Signum Car Chat
    Last Post: 29th March 2010, 15:42
  5. starting issue. . odd one
    By johnsav in forum Engine & Drivetrain
    Last Post: 25th July 2009, 16:27
