Ive sold my clocks but need to divorce them from the car,i have the car pass so just need to know what to do to divorce the clocks and ecu
On tech2 you select the year, then model (ie vectra), then Body, then Instruments... Theres a menu which says Reset on that, press that, then it will ask you for the cars security code, enter that, then it will divorce it.
If you are asking about any other software to do it, its not supported in this forum.
Thanks plasma,why is o*c*m not liked or used on here seen it said a few times
because thats a pirated version of software / hardware from the developer which could cause issues for the forum if we are seen to be hosting material / links for it
Ah i get you mate,on another note in my zafira ive put the auto lights switch and mirror in i also still have the window screen sensor but ive lost my wire that goes to the bonnet can i use the vectra loom one and is it a case of getting power to the mirror and sensor and green wire to under the bonnet fuse box then activated
not sure mate, not worked on zafiras
