Likes Likes:  1
Thread: Vectra C 2.0 DTI strange problem
    Feb 2020
    Staffordshire
    Trim : CLUB
    Engine : 2.0 DTI
    Default Vectra C 2.0 DTI strange problem
    Hi,
    I was driving my beloved 2.0 Vectra C estate home from work when the power steering went, thought the pump had gone and drove it home. Next day I went to start it and now it won't start, IV checked all the fuses ect all ok.
    Any ideas?
    Regular Member Jon1796's Avatar
    Sep 2015
    Norwich
    Vehicle : Vectra VXR x2
    Trim : VXR
    Engine : 28NEH
    Year : 07
    Mileage : 74,600
    Sounds like alternator.
    Feb 2020
    Staffordshire
    Trim : CLUB
    Engine : 2.0 DTI
    Had s new alternator last year, IV even fully charged the battery and it turns over fires up then instantly cuts out?
    Devon
    100 Post(s)
    Vehicle : insignia
    Trim : irmscher
    I would get codes read, we could all keep guessing till cows came home lol
    Irmscher Insignia CDTI 130
  5. Likes northpole liked this post
  6. #5
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    58 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    Can be 2 things immobiliser kicking in or a really dirty egr valve but my money is on the first one... that all said, I would deffo do a scan of the fault codes... don't forget to do the CIM as that will be where the immobiliser fault code will be stored.
  7. #6
    Feb 2020
    Staffordshire
    Trim : CLUB
    Engine : 2.0 DTI
    Thanks, ECU is not showing any fault codes, when you say do the CIM is there a way to scan that? Thought you could only read fault codes from the OBD?
  8. #7
    Apr 2016
    Ipswich
    58 Post(s)
    Mileage : 140000
    You can read each module separate that is if you have the right scanner either tech2 or the not talked about opcom/vauxcom....
    You can than read all the modules and any fault codes they might have stored...
    If you don't have that bit you have access to an elm327bt obd2 dongle and an andriod bt device download scanmyopelcan from the Google play store... it is capable of reading the following modules
    Engine/Cim/abs/autogearbox on the vectra platform...
    It won't erase the faultcodes but it will show you what is going on and give you the right code so you can find a solution quick enough.
  1. Strange starting problem - Vectra VXR
    By sinbrad in forum Electrical & ICE (including SatNav)
    Last Post: 30th September 2019, 22:10
  2. Strange problem Vectra C 3.0 V6 CDTI 177 HP
    By baboeba in forum Engine & Drivetrain
    Last Post: 9th June 2014, 16:24
  3. Strange problem with the Vectra?
    By ronnie63 in forum Engine & Drivetrain
    Last Post: 7th November 2013, 16:56
  4. 2.2 Direct Vectra Auto Gearbox - Strange Problem
    By Krusty3380 in forum Engine & Drivetrain
    Last Post: 7th May 2012, 21:12
  5. 2.2 2003 Vectra Strange Warning Light Problem?
    By sophos9 in forum Electrical & ICE (including SatNav)
    Last Post: 26th July 2007, 13:16
