Likes Likes:  3
Thread: Headlights
    Feb 2021
    Dorset
    Trim : Sri
    Engine : CDTI 150
    Default Headlights
    Hi, I realise this subject has most likely been discussed to death but I'm new so please forgive me......
    I have a facelift Sri and have been through various bulbs trying to find something that gives the best combination of night vision and looks...I currently have 6000k hid bulbs with 35w ballast boxes and they are not bad..I do have 55w boxes but they tend to flicker quite a lot (so do the 35w but not as bad)...any ideas why?
    I have tried led bulbs and they are ok but not brilliant and I have issues with my led sidelights blowing when I had the dipped beam LEDs fitted
    Also I have been looking at changing the whole headlight units for halo ring units..seen a few on eBay that look quite nice
    Any suggestions???
    Regular Member Vwdub2000's Avatar
    Apr 2018
    Scotland
    Vehicle : Vectra c estate
    Trim : Life
    Engine : 1.8
    I'm using 6500k with 55w a/c with anti flicker capacitors. Its flicks on start up for 5 seconds then settles.
    https://www.amazon.co.uk/dp/B07GXH5F...HC24S7MGGGFWET
    Sent from my SM-N960F using Tapatalk
    Feb 2021
    Dorset
    Trim : Sri
    Engine : CDTI 150
    Quote Originally Posted by Vwdub2000 View Post
    I shall give them a go...thanks
    Feb 2015
    Copenhagen
    Vehicle : Opel Vectra
    Trim : Caravan Elegance II
    Engine : Z18XER
    Mileage : 170.000km
    If you set the headlight to Xenon it should stop flickering, iirc.
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    58 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    it should but don't forget to add fuse f9 in the engine fuse box or it won't help
  6. Likes NielsJ, 150Estate, Vwdub2000 liked this post
  7. #6
    Feb 2021
    Dorset
    Trim : Sri
    Engine : CDTI 150
    Quote Originally Posted by NielsJ View Post
    How would I go about doing that?
  8. #7
    Midlands - Vxr Owning Dick Dog_Book's Avatar
    Oct 2013
    Derby
    309 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Quote Originally Posted by 150Estate View Post
    The best way would be to research the massive amount of info thatís held in the forum about it so you know all the aspects rather than come across each issue at a time.
    There should be loads in the modifying section further down as well as in here when people have put the posts in the wrong place.
    There might be some how 2ís but I canít remember it was over 6 years ago when I did mine.
    Teapot Tuned 255/300
    Tech2 & MDI diagnostics + SPS
  1. Replies: 8
    Last Post: 11th May 2014, 13:35
  2. For Sale: Sri preface headlights and Facelift sri headlights
    By jon1.9cdti in forum Parts for sale
    Last Post: 24th April 2013, 23:18
  3. SRi Headlights
    By Danwells72 in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 20th October 2008, 09:11
  4. Headlights
    By StephNET in forum Electrical & ICE (including SatNav)
    Last Post: 18th January 2008, 00:39
