Thread: Z20NET not starting in cold weather !!HELP!!
    Dec 2018
    Tammisaari
    Vehicle : Vectra c
    Trim : GTS
    Engine : Z20NET
    Mileage : 189500
    confused Z20NET not starting in cold weather !!HELP!!
    So my 2004 Vectra C 2.0t suddenly didn't start in the cold weather yesterday (-15 celcius today). I've tried to jumpstart the car but it still wont start even though it cranks good. It did start by pushing it although that was quite a lot of effort before it finally started. When I got it running it was running smooth without any problems. When it was warm it started well but after a night of sitting in the freezing weather it won't start again. Today I put some starter fluid through the throttle body but it wouldn't start, I guess it would have started by pushing it but that won't fix the issue.
    Have you got similar problems and what could this issue be?
    To clarify:
    -Cranks good
    -Fuel pump is working
    -Fuel filter recently changed
    -Starts by pushing
    -Runs smooth when warm
    Any suggestions/help would be greatly appreciated.
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    93 Post(s)
    Vehicle : Vectra C Saloon( sadly died at age 20 due to a hart attack)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    if the car refuses to start when cold there will be an error logged in the ECU so i would scan it but it could be something as simple as a duff crankshaft position - or camshaft sensor that is causing it not to start... now don't go and change them without scanning the car.... as it could as well be a fuse that has blown... so scan the ecu.
    Dec 2018
    Tammisaari
    Vehicle : Vectra c
    Trim : GTS
    Engine : Z20NET
    Mileage : 189500
    I forgot to mention but I also scanned the car for fault codes but nothing showed up.
    This morning I tried starting it again and it started for about 2 seconds (very roughly) and after that it shut off and didn't start again.
    Berkshire
    29 Post(s)
    Vehicle : Toyota
    Trim : Yaris Hybrid
    Engine : 1.5 Hybrid
    Year : 2021
    Mileage : 5525
    could be faulty plugs /coil pack or Maf ?
    Dec 2018
    Tammisaari
    Vehicle : Vectra c
    Trim : GTS
    Engine : Z20NET
    Mileage : 189500
    I changed the spark plugs a few weeks ago so maybe not that then? Can it be coil pack or MAF even though it runs and starts good when it is running?
    Dec 2010
    London
    8 Post(s)
    Vehicle : Hyundai Ioniq Hybrid
    Trim : Premium SE
    Engine : 1.6 with 32KW motor
    Check coolant temp sensor reading
    Dec 2018
    Tammisaari
    Vehicle : Vectra c
    Trim : GTS
    Engine : Z20NET
    Mileage : 189500
    Coolant temperature reading was -12 celsius, same as air intake temperature.
  1. Cold weather affecting car?
    By b6x in forum Electrical & ICE (including SatNav)
    Last Post: 9th December 2010, 22:31
  2. cold weather you think?
    By chris1804 in forum Electrical & ICE (including SatNav)
    Last Post: 1st January 2010, 20:27
  3. Cold weather
    By petel in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2008, 12:57
  4. Cold Weather = Rough Starting
    By DesignforLife in forum Engine & Drivetrain
    Last Post: 10th February 2007, 10:21
  5. Cold weather
    By ed taylor in forum General Chat
    Last Post: 26th January 2007, 20:02
