Results 1 to 2 of 2
Thread: Brake line re-route
    Regular Member OiNath's Avatar
    Aug 2020
    Penyffordd, Holywell, UK
    Engine : 1.8 vvt
    Mileage : 126500
    Default Brake line re-route
    Hello all, I have been quite absent from this site and I do apologize.
    I just wanted a confirmation, ideally from an MOT tester or mechanic but if not... I've had a brake pipe burst on the back of my 1.8 Sri, right by the fuel filter, the line feeds the nearside rear brake, but it goes up and behind the fuel tank, would it be acceptable, or would it pass MOT if I take the original out and re-route along the front of the rear subframe instead? Much easier than going round the tank. I will be securing it with all the original mounting clips and new clips on the subframe. I really don't fancy having to take the fuel tank off to replace one pipe.
    Thank you in advance.
    Regular Member SteveSxi's Avatar
    Nov 2013
    Bristol
    Trim : Sxi
    Engine : 1.8
    That's the criteria for brake pipes. As long as it's all nicely routed and secure, it should be fine
    Sent from my ELE-L29 using Tapatalk
  1. leaking brake line
    By john norris in forum Suspension, Wheels & Brakes
    Last Post: 8th October 2016, 15:45
  2. Hi line brake light
    By fire in forum Vectra C / Signum Car Chat
    Last Post: 9th July 2016, 12:52
  3. Brake line removal
    By mparks8590 in forum Suspension, Wheels & Brakes
    Last Post: 5th December 2010, 17:47
  4. Brake line corrosion
    By barry087 in forum Suspension, Wheels & Brakes
    Last Post: 17th October 2010, 21:31
  5. Goodridge brake line kit
    Last Post: 25th October 2009, 11:09
