Thanks Thanks:  3
Likes Likes:  3
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Wiper alignment
  1. #11
    Apr 2016
    Ipswich
    80 Post(s)
    Vehicle : Vectra C Saloon
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Year : 2003
    Mileage : 140000
    Quote Originally Posted by Castiel View Post
    Came across this thread at just the right time. Having the same problem for a few years and repairs are not working anymore with the driver side arm striking the pillar (which it didn't do when the repair was first done).
    Just one quick and possibly silly question. I watched the video linked to above (and quoted below)
    Why do the linkage arms get replaced "upside down". The original ones taken off have the "open" side facing down while the new ones are open side up. I thought it was a mistake on the video but on X8R's website they have the same "mistake" in their pictures. Is this intentional or does it not matter? The placement of the arms?
    they aren't upside down they are the right way up, the old ones look like they are the other way around, but remember the new linkages have been redesigned to address the problem of the original... so they are not upside down they are mounted the right way up.
  2. #12
    Regular Member Hoggle's Avatar
    Jan 2014
    Cv
    Vehicle : Vectra c SRI CDTI 150
    Trim : SRI
    Engine : Z19DTH
    Year : 2008
    Mileage : 117,000
    Right after years and years and years this problem is now fixed. I bought a second hand complete unit (linkage and wiper motor). The problem immediately repaired itself fortunately the second hand unit was stamped with 2018 so presume it didn’t have much mileage on it.
    I did try adjusting the stubby arm/ experiments with it but it just wouldn’t work I was just really leather to spend over £100 on a motor to find that I still had the fault. My advice would be pick up a second hand motor to anyone on this predicament. I’d also be inclined to just buy a new linkage assembly of its proven that the motor is at fault.
  3. Likes northpole liked this post
  4. #13
    Regular Member OPC's Avatar
    Mar 2009
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Engine : 1.9 CDTi 150
    Year : 2008
    Quote Originally Posted by Hoggle View Post
    Right after years and years and years this problem is now fixed. I bought a second hand complete unit (linkage and wiper motor). The problem immediately repaired itself fortunately the second hand unit was stamped with 2018 so presume it didnít have much mileage on it.
    I did try adjusting the stubby arm/ experiments with it but it just wouldnít work I was just really leather to spend over £100 on a motor to find that I still had the fault. My advice would be pick up a second hand motor to anyone on this predicament. Iíd also be inclined to just buy a new linkage assembly of its proven that the motor is at fault.
    You say you fixed it finally with a new motor? Surely the small link rod attaching the motor has a set position, I think horizontal? I've just fitted new oe linkage and same problem. I also didn't pay attention when fitting this tbh.....again it can't be my motor surely, I assume its the position of the small arm that is meant to be at the point where its at its furthest, so it then pulls wipers up?
  5. #14
    Apr 2016
    Ipswich
    80 Post(s)
    Year : 2003
    Mileage : 140000
    You nailed it... but what you might think is the right position might be a little lower or higher... just move it until it's right...
  1. Replies: 8
    Last Post: 4th June 2019, 20:07
  2. wiper alignment
    By unreal_event_horizon in forum Vectra C / Signum Car Chat
    Last Post: 23rd March 2013, 23:44
  3. Wiper Linkage - failed O/S Wiper
    By silver-tongue in forum Engine & Drivetrain
    Last Post: 15th February 2011, 10:29
  4. FLAT FUSION WIPER BLADES KYODO WIPER BLADES Dynamic Flexi Wiper Blades
    By korlinski in forum Vectra C / Signum Car Chat
    Last Post: 25th June 2007, 19:40
