Thanks Thanks:  3
Likes Likes:  3
Results 1 to 10 of 14
Thread: Wiper alignment
    Regular Member Hoggle's Avatar
    Jan 2014
    Cv
    Vehicle : Vectra c SRI CDTI 150
    Trim : SRI
    Mileage : 117,000
    Default Wiper alignment
    Hi
    Iíve had my vectra about 7 years now. About 5 years ago I had the well known problem of the linkage breaking.Iíve survived off the repair kits for the last 5 years but the wipers have never been quite right colliding with the bottom of the scuttle etc. I have spent hours every time attempting to align them correctly.
    last year I thought enough was enough and bought a replacement linkage from vauxhall assuming it was slop in the cheap repair linkage that was responsible.
    The problem continues and over the years Iíve lost count of the hours/Iíve spent trying to rectify/ research this.
    Iíve even bought a brand new wiper arm as I read some where there was a suggestion this could be at fault.
    what Iíve been doing is removing the wipers.
    -Turn the wipers on then off
    • allow the spindle to return to its stationary stop/start position.
    • fitting the wiper arm approximately
    • turn on and see what the result is.
    • if it hits the a pillar I stop and repeat the above lowering the initial position of the wiper and vice versa if it hits the scuttle. Iíve tried minute movements and large differences in the start position all either have the same result or arenít right.
    the issue I seem to be having is the wiper seems to go past itís start position a few inches (collide with the scuttle) then return to the start position. So the spindles start position appears to have no bearing on where i
    someone must have had this issue with the vectra wipers too.
    Any help would be appreciated
    Iím beginning to query whether the wiper motor has any sort of alignment issues with the linkage itself.could this be an issue?
    thanks
    Regular Member AndySignum2.2's Avatar
    Oct 2016
    Trim : 2.2 Direct Exclusiv
    Engine : Not sure
    I have several thoughts on the wiper issue......
    Are the teeth worn on the wiper arm and/or the spindle?
    Its possible that the linkage arms or at least one of them are worn
    My last thought at this moment in time is, when you you allow them to sit in their resting position do you move them a lot or just one tooth at a time?
  3. Thanks Hoggle thanked for this post
  4. #3
    Regular Member skidmark1's Avatar
    Sep 2010
    cornwall
    Vehicle : 2.2 Direct
    Trim : SRI
    Engine : YH 2.2 petrol
    Mileage : 106000
    I replaced my whole assy this time with a second hand unit of the bay, the one off my car I had replaced the tie rods about three years ago and was still in good condition apart from the Chinese replacement rods were worn out, since replaced these , cleaned and lubed and is now sitting under the bench for next time, mine was hitting the pillar so lowered the driver side one but as you say go to far and it hits the scuttle, this on mine was all due to wear in the plastic bushes on the rods
  5. Thanks Hoggle thanked for this post
  6. #4
    Jan 2014
    Cv
    Trim : SRI
    Mileage : 117,000
    Hi thanks for the responses - so I’ve read the thing about move one tooth at a time before and just don’t think it’s do able as the teeth are so small other manufacturers seem to have big toothed gears making this far easier. The linkage was changed out for a brand new vauxhall assembly around 3 months ago. The tooth’s appears fine on the assemble itself. In terms of the wiper arms I bought a brand new one and it appears the the spindle cuts the grooves into the new wiper arms. The issue seems to be occurring on passenger side and the drivers side.
    I even tried sticking a post It note to the windscreen and putting markings and working it down/ up tiny amounts in reinstall.
    surely this is a 10 minute job a side I’d even take it to a garage but can’t see what they could do what is different to what I’m doing.
    it’s been suggested that the motor is at fault on another forum but it would have to be massively coincidental for this to become faulty when the issue with the linkage occurred although I am willing to try changing this.
  7. #5
    Engine : 1.9 CDTi
    Sounds like the short arm between the motor and linkage is in the wrong place
  8. Thanks Hoggle thanked for this post
  9. #6
    Jan 2014
    Cv
    Trim : SRI
    Mileage : 117,000
    Quote Originally Posted by lee gsi View Post
    Iím thinking you could be right - as When I moved the motor from the old assembly to new I didnít give placement of the arm from the linkage to the motors second thought. I assumed you could just reattach it.
    what I may do is remove the plastic scuttle loosen the the arm from the motor to the and try it in some different positions.
    Unless does anyone know the correct position this should be sat when assembled?
  10. #7
    Regular Member Daywalker's Avatar
    Aug 2007
    Mitkunai k, Kaunas raj
    Vehicle : Kia Ceed
    Trim : GT line
    Engine : 1.6crdi
    Year : 2017
    If you watch this video from youtube it does show the parked position @ 2.28 ( hopefully clear enough) which may help you with alignment https://www.youtube.com/watch?v=TnKSY-6pIT4
  11. #8
    Jan 2014
    Cv
    Trim : SRI
    Mileage : 117,000
    Quote Originally Posted by Daywalker View Post
    thanks for that - I’ll have a look and have a play when I’m off and update
  12. #9
    Sep 2018
    sunderland
    Vehicle : exclusiv
    Trim : exclusiv
    Engine : 1.8 vvt
    I had this issue litterally just yesterday as I replaced ( upgraded ) my linkage. The problem is the short arm from the actual motor to the linkage. It is too far down on the splines, you need to loosen the nut and move the arm up on the splines in the direction of the roof , I suggest you move a couple of splines at a time until you reach the correct alignment. I scratched my head for a few hours until I realised that the wipers were going too far down then returning to " parked ".
  13. Likes Hoggle liked this post
  14. #10
    Regular Member Castiel's Avatar
    Mar 2016
    Ireland
    Trim : GTS
    Engine : 1.8
    Came across this thread at just the right time. Having the same problem for a few years and repairs are not working anymore with the driver side arm striking the pillar (which it didn't do when the repair was first done).
    Just one quick and possibly silly question. I watched the video linked to above (and quoted below)
    Why do the linkage arms get replaced "upside down". The original ones taken off have the "open" side facing down while the new ones are open side up. I thought it was a mistake on the video but on X8R's website they have the same "mistake" in their pictures. Is this intentional or does it not matter? The placement of the arms?
  15. Likes Hoggle liked this post
  1. Replies: 8
    Last Post: 4th June 2019, 20:07
  2. wiper alignment
    By unreal_event_horizon in forum Vectra C / Signum Car Chat
    Last Post: 23rd March 2013, 23:44
  3. Wiper Linkage - failed O/S Wiper
    By silver-tongue in forum Engine & Drivetrain
    Last Post: 15th February 2011, 10:29
  4. FLAT FUSION WIPER BLADES KYODO WIPER BLADES Dynamic Flexi Wiper Blades
    By korlinski in forum Vectra C / Signum Car Chat
    Last Post: 25th June 2007, 19:40
