25th January 2021, 22:51
#31
Originally Posted by
plasma
if it was stiff to rotate at all then yeah, sounds like its had water in it and seized it up... you can try greasing it up and then apply 12volts directly to the 2 pins to see it spin up and chuck grease at ya lol
Should i spray WD 40 or drip 3in1 onto the armature itself? Would that interfere w the brushes? I've put some 3in1 on the "axle", top and bottom.
25th January 2021, 22:57
#32
Dog_Book
Personally if i was intending on keeping the car for a few more years id replace the lot, certainly the fan motor unit. But thats going on the idea of not returning to the job, one visit no return id rather do it all once and not go back knowing it would be trouble free for years.
Many thanks Dog_Book, good advice, I certainly don't want to ****** about with this any more before this car goes to the great showroom in the sky. Any recommendation on make? I see 3 makes at least: NRF, Nissens and Valeo. Cheers Ian
25th January 2021, 23:03
#33
IanR1969
I always stick with what the factory put in, if it lasted this long (13 years in my case) a new exact replacement will last just as long again. But those in the know on here know i tend to spend more on mine than most.
Teapot Tuned 255/300
Tech2 & MDI diagnostics + SPS
Post Thanks / Like - 1 Thanks, 0 Likes
26th January 2021, 12:25
#34
Dog_Book
yeah he really doesn't mess about and buys new oem parts constantly, the person that'll buy his car when he finally decides to let it go will buy a car in A-class condition, he's not showing it love it almost borders insanity... and i'm not even joking look in his cars diary... you'll wonder why he chances stuff sometimes even though it's still working fine...
26th January 2021, 22:19
#35
Dog_Book
Thanks DB, I run my cars into the ground without sentiment (137k+ on the clock, tatty, sounds like you'd hate it), but am happy to spend a few quid more for the devil I know: Valeo it is! Cheers, Ian
26th January 2021, 22:59
#36
Last update on this one - connected it and it spins as directed by the ECC, i.e. 0 is off, 7 is fast and all points in between, cracking! Will put it all back properly and see if it all works but looks like that's it for now. Many thanks for all the guidance! Cheers, Ian
29th January 2021, 20:36
#37
IanR1969
Have you tried with the original ECC again since the new fan was mounted?
30th January 2021, 13:27
#38
NielsJ
Hi Niels, no, just put it all back this am and it seems to work. Do you suspect something? Happy to do a swap over at some point to check, but the ECC was dodgy for years before the fan seemed to be playing up...
30th January 2021, 13:30
#39
as probably said, the rotary encoder plays up making it jump number, never looked at fixing that, but have fixed an issue where you have to thump the centre wheel to get it to work lol, that needed solder joints reflowing around it
30th January 2021, 23:29
#40
IanR1969
No, I was just curious as you started changing one thing, but it only worked when you changed another thing. If the ECC has been dodgy for years it probably still is. Re-soldering the encoder as plasma suggest might fix the problem. I don't know if the push button and rotary function is in the same component, but I would think so, and it's worth a try :-)
