24th November 2020, 16:11
#1
UEC Replacment
Good afternoon Guys.
Im looking at options to change my UEC as it became unexpectedly wet and i believe its the cause of the poor running/stalling once i dried it out.
Car vectra vxr 255
UEC ident GF
the new UEC must be able to support Xenon/AFls.
If i cant get a like for like replacement (GF ident) then any suggestions on what one i should try and get?
My tech 2 shows no error codes and changing the UEC is cheaper than the chains but i dont belive that the chains are a cause.
24th November 2020, 19:17
#2
@plasma the only guy I know who would know.
Teapot Tuned 255/300
Tech2 & MDI diagnostics + SPS
24th November 2020, 19:25
#3
24th November 2020, 19:40
#4
Try other than uk flea bay as rare over here.
25th November 2020, 12:30
#5
@Jon1796 Thanks for that will check it out.
What is the actual differences between the G's? So mines is a GF, but then it goes GG,GH,GL etc.
Last ones seem to be JQ/W
25th November 2020, 12:46
#6
1 (93186624) (62 37 155) box, fuse, engine wiring harness, with fuses and relays (services production ident gk) (plug connection f35 in the bec: Fuse 40a) (plug connection f36 in the bec: Fuse 30a) (nls.- use 93189486) [(c)-48999999, (c)61000001-61144738] 1
1 93189486 12 36 173 BOX, FUSE, ENGINE WIRING HARNESS, WITH FUSES AND RELAYS (IDENT JU) (PLUG CONNECTION F35 IN THE BEC: FUSE 40A) (PLUG CONNECTION F36 IN THE BEC: FUSE 30A) (PRODUCTION NO. 13247794) [(C)-48999999, (C)61144739-61999999] 1
some are for specific engines, some are specific for AFLS, some are for standard and some are superceeded..
Post Thanks / Like - 1 Thanks, 1 Likes
25th November 2020, 14:52
#7
@plasma
thanks for that, any recomendations as to what one to get? I need it for the pertrol 2.8 with AFLs
I have the green 30amp fuse at the front of the UEC.
25th November 2020, 15:00
#8
the ones listed above will do you mate, others not so much so
25th November 2020, 19:21
#9
Had a look at mine and it’s identifier is JK if that helps? Not listed above but mines a 280 if it makes any difference
Thats not a REC out look that’s a nobcom look.
25th November 2020, 19:33
#10
mmm.
1 (93192724) (12 38 703) BOX, FUSE, ENGINE WIRING HARNESS, WITH FUSES AND RELAYS (IDENT JK) (NLS.- NO REPLACEMENT PART) (PRODUCTION NO. 13241894) Z22SE[L61],Z22YH[LCH] [(C)71000001-, (C)78-] 1 12H X1373
