Thread: Pad wear with disc size??
    Regular Member Hoody86's Avatar
    Jan 2019
    Fife
    Trim : Exclusive
    Engine : 1.9 cdti Z19DTH
    Mileage : 127K
    Default Pad wear with disc size??
    Hi guys just bough a set of what I belive are 302mm front calipers from a 2.2 in the breakers this was confirmed by the reg in my work. Strange thing is though the pads seem to not be wearing at the top and eventually are going to touch when the pads reach about half there wear. Is it possible to fit 314mm discs?? As its about 4/5mm of the pad not wearing???
    Thanks in advance to any reply and I will try get pictures later.
    Jan 2019
    Fife
    Trim : Exclusive
    Mileage : 127K
    This is the only markings on them
    Midlands - Vxr Owning Dick Dog_Book's Avatar
    Oct 2013
    Derby
    303 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    What about the rest of the caliper?
    Teapot Tuned 255/300
    Tech2 & MDI diagnostics + SPS
    Dec 2010
    London
    Vehicle : Hyundai Ioniq Hybrid
    Trim : Premium SE
    Engine : 1.6 with 32KW motor
    Standard for 2.2 is 285mm
    Jan 2019
    Fife
    Trim : Exclusive
    Mileage : 127K
    These came of a 2.2 ans EPC lists 302mm.
    Dog_Book I could d see any other markings but I'm attacking the bleed nipples today so will have another going over. Just think the way the pads are wearing is strange.
    VIP-Member sulten's Avatar
    Øvre Årdal, Norway
    13 Post(s)
    Vehicle : Opel Vectra C
    Trim : Cosmo OPC Line
    It looks like a two-part callipper, 1 part aluminum and 1 part cast iron. Then there are 314 or 345 callippers most likely 314.
    Kristian
    68 Diplomat-A 46S
    95 Vectra-A C20NE
    07 Vectra-C Z19DTH
    Regular Member Entharion's Avatar
    Nov 2018
    Netherlands
    Trim : GTS
    Engine : 2.0 Turbo (Z20NET)
    These ARE 314/345mm calipers...
    This is a pic of my 314's: 20200226_171214.jpg
    Only difference between the two is the length of the mounting bracket, but I think yours must be 314's as well...
    The brake kit OE number is 93186299
    Jan 2019
    Fife
    Trim : Exclusive
    Mileage : 127K
    So looks like some ones put 314 calipers on with 302 discs as I suspected as my caliper is the exact same as that. This would explain the pads to wearing properly
    Oct 2013
    Derby
    303 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Quote Originally Posted by sulten View Post
    That’s why I asked to see the rest of the caliper as the 302 is a 1 piece caliper
    Jan 2019
    Fife
    Trim : Exclusive
    Mileage : 127K
    Will get pics
  1. brake disc wear
    By howardeno in forum Suspension, Wheels & Brakes
    Last Post: 28th April 2014, 09:57
  2. what size are my disc's?
    By dannydm1 in forum Suspension, Wheels & Brakes
    Last Post: 18th December 2011, 16:19
  3. What size disc's
    By chrisvectra in forum Vectra C / Signum Car Chat
    Last Post: 5th July 2011, 18:21
  4. what size disc do i need
    By Grimo72 in forum Suspension, Wheels & Brakes
    Last Post: 3rd May 2010, 17:47
  5. What size disc's?
    By mishima in forum Suspension, Wheels & Brakes
    Last Post: 9th May 2009, 18:31
