Likes Likes:  1
Thread: Pillar pull out clip removal without damage?
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    5 Post(s)
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    Default Pillar pull out clip removal without damage?
    Im planning on dropping my headlining as ive got a new roof loom ( for my rear light and illuminated visors ) and also rear dimming mirror. My only worry is those horrible clips that hold the A,B,C pillars in place. No matter how i try i always chew them to bits getting the things to release. I tried for hours today on the donor car and had about 10 different plastic trim tools which either broke or just didnt have the umph to get them free. The only way was to use a screwdriver but it chewed up the corners.
    I dont mind on the donor car as its beings scraped but it will look awful in my car. is there a knack to getting them up and to release without damage?
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    53 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    you do know there are special tools to remove trim without damage? they are called trim removal tools... basically it is a set of little and bigger plastic levers.. use those if you can't just replace stuff with normal tools without damage... i removed the stuff from my C-pillar with normal tools without a problem... and no I'm not using a special way to remove the stuff.
    13 Post(s)
    The OP did mention that he was using trim removal tools.
    "had about 10 different plastic trim tools which either broke or just didnt have the umph to get them free"
  4. Likes llamallama liked this post
  5. #4
    VIP-Member Jon1796's Avatar
    Sep 2015
    Norwich
    Vehicle : Vectra VXR x2
    Trim : VXR
    Engine : 28NEH
    Year : 07
    Mileage : 74,600
    Just use a blunt table knife.
  6. #5
    Aug 2011
    Basingstoke
    5 Post(s)
    Trim : SRI
    Quote Originally Posted by northpole View Post
    I do have a set, in fact several sets.
  7. #6
    Apr 2016
    Ipswich
    53 Post(s)
    Mileage : 140000
    Oww I saw but you have plastic trim removal.tools that are just plastic.moulded.crap.amd than you have the professional stuff that is fibre reinforced...
    I just use normal screw drivers, flat heads with different sized heads... never broke a a clip and my car is already 17 years old the stuff is always hard to remove.
    Longstory short I never use those trim removal tools although I got a perfectly fine set to use... because although mine are fibre reinforced I can see them snapping in my hands... so I just use flathead screw drivers.
  8. #7
    Aug 2011
    Basingstoke
    5 Post(s)
    Trim : SRI
    Ok
    I wasn't sure if there was a technique i.e instead of just pulling it out maybe levering at an angle or something.
    Vauxhall want 14 quid for a new one
  9. #8
    13 Post(s)
    Quote Originally Posted by justin32 View Post
    Ok
    If you have the part No, then Google it, or try eBay. I recently had to buy a new side panel for my drivers seat. £18 delivered from eBay, genuine part, brand new. Over double the price from Vauxhall.
  10. #9
    Aug 2011
    Basingstoke
    5 Post(s)
    Trim : SRI
    That was Ebay price for new. Looked at second hand ones but they are all chewed up around the edges
  11. #10
    Administrator plasma's Avatar
    On the Forum
    532 Post(s)
    Engine : 150
    Mileage : 74000
    never need tools for the vectra. A pillars can come out with a little force or dislodge the clip enough to get under it without any effort, same for the B and C pillars
  1. Door pillar trim removal
    By stickerlee in forum Styling
    Last Post: 15th August 2014, 08:21
  2. A-Pillar trim removal
    By jammy_c in forum Electrical & ICE (including SatNav)
    Last Post: 11th September 2012, 15:26
  3. Internal Pull Handle Removal Help!
    By aaruck in forum Bodywork & Interior
    Last Post: 22nd February 2009, 20:50
  4. A Pillar Removal
    By Big Gaz in forum Bodywork & Interior
    Last Post: 1st June 2008, 12:03
  5. A pillar trim removal.
    By rushy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2007, 21:03
