Results 1 to 2 of 2
Thread: Speedometer cluster backlight issue.
    Jul 2019
    Oldham
    Vehicle : Insignia
    Trim : SE
    Engine : 1.8
    Thumbs up Speedometer cluster backlight issue.
    Morning guys.
    I have had my insignia for just over a year now and I starting to get an issue with the backlight to the speedo/fuel gauge/oil etc.
    When I get in 9 times out of ten everything is ok then the light behind the fuel gauge is the first to go out, then rev counter. It is very sporadic. It could be 1or 2 light but tends to be 3.
    Is this a common fault?
    Is there an easy fix? Or is this an expensive fix?
    I have a 09 plate 1.8 insignia Se
    Any help or advice would be greatly appreciated....
    VIP-Member
    Sep 2020
    Bilston
    Vehicle : Vauxhall Insignia
    Trim : Hatchback
    Engine : 2.0
    Year : 14
    Easy way is try someone to replace dead smd (price is depend) or new speedo cluster but will need to relearn to your car. So probably if is dead smd will coat around £50 (may be to be done) or replace your cluster and programming for around £100 (again depend of price to buy other IPC and person where will reprogram)
    Sent from my iPhone using Tapatalk Pro
  1. Speedometer help
    By andy100102 in forum Styling
    Last Post: 23rd December 2013, 17:03
  2. Strange issue with instrument cluster!
    By Chip in forum Electrical & ICE (including SatNav)
    Last Post: 6th March 2013, 13:49
  3. Rear Nearside Light Cluster Issue
    By cholyoak in forum Electrical & ICE (including SatNav)
    Last Post: 3rd April 2011, 11:37
  4. led speedometer
    By luke.oldham in forum Electrical & ICE (including SatNav)
    Last Post: 1st April 2010, 07:48
  5. Changing speedometer ...
    By hans_vledder in forum Electrical & ICE (including SatNav)
    Last Post: 4th May 2008, 14:37
