20th October 2020, 08:46
#1
Correct AFL UEC?
What is correct UEC to full can prefacelift vec? I'm planning to retrofit afl xenons. I have all other parts. But correct uec missing.. (2.0Turbo sri(gts) LHD. Euro model)
Do I need opcom/tech2 session, to program different uec to my car? Or is it plug & play, and afl enable via tech2?
TIA
20th October 2020, 12:07
#2
yes you'll need to program it, just don't know which one you'll need as going from half canbus to full canbus means a bunch of wires need to be changed over and possibly adding some extra.. the man to ask is called @plasma.. he should now get a notification but he isn't always online so it is best to send him a PM.
20th October 2020, 13:29
#3
Originally Posted by
northpole
My car is 2005, Full can
20th October 2020, 14:07
#4
Demosta
Still it has to be programmed ... less work if yours is full canbus
20th October 2020, 17:16
#5
if it was a diesel i would be able to tell you. EPC doesnt list it by engine type unfortunately but if you get me a reg or vin from a 2.0T already with it i can then find out which one it uses
20th October 2020, 18:47
#6
plasma
I send pm
20th October 2020, 20:47
#7
I reply PM..
And for info purposes of this thread if any one else stumbles across it, I have found the following info from a VIN of same spec vehicle with afls.
EPC is now working again, they list 3 idents for this VIN (they dont narrow it down unfortunately)
IDENT EL - 1 (93184293) (62 43 305) BOX, FUSE, ENGINE WIRING HARNESS, WITH FUSES AND RELAYS (IDENT EL) (PLUG CONNECTION F35 IN THE BEC: FUSE 30A) (PLUG CONNECTION F36 IN THE BEC: FUSE 20A) (PLUG CONNECTION F15 ADDITIONAL FUSE 10 AMP INSERT) (NLS.- NO REPLACEMENT PART) [(C)51000001-51999999, (C)58000001-58999999]
IDENT EM - 1 (93184288) (62 43 301) BOX, FUSE, ENGINE WIRING HARNESS, WITH FUSES AND RELAYS (IDENT EM) (PLUG CONNECTION F35 IN THE BEC: FUSE 40A) (PLUG CONNECTION F36 IN THE BEC: FUSE 30A) (NLS.- NO REPLACEMENT PART) [(C)51000001-51999999, (C)58000001-58999999]
IDENT ED - 1 93184291 62 43 303 BOX, FUSE, ENGINE WIRING HARNESS, WITH FUSES AND RELAYS (IDENT ED) (PLUG CONNECTION F35 IN THE BEC: FUSE 50A) [(C)51000001-51999999, (C)58000001-58999999] 1
