Thread: 13 pin dedicated unit problem
    New Member vininpreston's Avatar
    Sep 2013
    Preston
    Vehicle : Vectra C
    Trim : Design
    Engine : 1.9 cdti
    Default 13 pin dedicated unit problem
    Hello to all,
    Hope this is the right forum?
    My outfit:- 2005 Vectra Design 1.9 cdti, 150bhp
    The GM dedicated 13 pin towing module is only giving out a permanent +12v.
    There should also be a ignition switched 12v+ , this would power the fridge in the caravan whilst towing.
    But I only have the permanent 12v+
    Do I need to get the ECU programmed to enable this ignition switched pin.?
    Any help welcome.keep safe
    Vin in Preston Lancs.
    Regular Member kenp's Avatar
    Feb 2008
    Kr. Hyllinge, Denmark
    Vehicle : Vectra C
    Engine : 2.2 Direct
    Probaly the “ADD-on” loom is not fittet, or fuses, not fittet.
    Sep 2013
    Preston
    Vehicle : Vectra C
    Trim : Design
    Engine : 1.9 cdti
    Hello, Thanks for your imput.
    Did not know you need a Add-on loom for a dedicated 13 pin plug. The fuse in REC is OK No 18 I think it was.
    The permanent live is OK, feeds 12v through to caravan but nothing on pins 10 which is the ignition switched live.
    Feb 2008
    Vehicle : Vectra C
    Engine : 2.2 Direct
    You Can make your own straghit from the rec.
    but the correct one goes to the batteri at the front of the car.
    i alså have 13 pin in my car, bus as i dont tow a caravan, i didnt wanted to fit the extra loom, or make it work out off the rec... (there is switched live there, and live, you can via a relay make your own...
    Sep 2013
    Preston
    Vehicle : Vectra C
    Trim : Design
    Engine : 1.9 cdti
    Thanks again, do not really want to splice into the REC.
    Very strange when a GM dedicated 13 pin socket is fitted but the switched live is not active?
    VIP-Member sulten's Avatar
    Oct 2008
    Øvre Årdal, Norway
    13 Post(s)
    Vehicle : Opel Vectra C
    Trim : Cosmo OPC Line
    Engine : Z19DTH
    Kristian
    68 Diplomat-A 46S
    95 Vectra-A C20NE
    07 Vectra-C Z19DTH
  1. Dedicated towbar wiring kit
    By jimboy26 in forum Electrical & ICE (including SatNav)
    Last Post: 6th January 2016, 21:10
  2. Is there any Dedicated Insignia Forums?
    By markgray in forum Insignia car chat
    Last Post: 29th June 2012, 11:56
  3. Towbar wiring - gm dedicated harness
    By Richie_rich in forum Electrical & ICE (including SatNav)
    Last Post: 19th June 2012, 18:28
  4. Dedicated towbar wiring
    By cus2000 in forum Vectra C / Signum Car Chat
    Last Post: 29th May 2012, 12:48
  5. New head unit problem, Help!
    By Butler in forum Electrical & ICE (including SatNav)
    Last Post: 5th January 2009, 09:22
