Likes Likes:  1
Results 1 to 7 of 7
Thread: 1.9 150 Main cat drilling
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    5 Post(s)
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    Default 1.9 150 Main cat drilling
    Im thinking about drilling out the guts on the main cat converter and was wondering if i just need a long drill bit or are the internals like the Pre cat and made of metal?
    Also, will i need to remove the exhaust section and tip it up so all the bits come out?
    Apr 2016
    Ipswich
    52 Post(s)
    Vehicle : Vectra C
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Year : 2003
    Mileage : 140000
    nope it is a normal cat... all you need is a big drill bit and a long chisel and bash the lot out
    Mar 2010
    Trim : Design
    Engine : 1.9 CDTi
    I used a meter long SDS drill bit and a length of angle bar and a hammer.
    Dont forget it will also need to be mapped out.
    Aug 2011
    Basingstoke
    5 Post(s)
    Trim : SRI
    Quote Originally Posted by lee gsi View Post
    Its the main cat with no sensors and not the Pre cat which has the sensor on it
    Apr 2016
    Ipswich
    52 Post(s)
    Vehicle : Vectra C
    Year : 2003
    Mileage : 140000
    Oww and ofcourse you need to take it of the car and make sure you get all the bits out... if you don't they might clog up the pipe down the line or the rear exhaust box(es).. you used to be able to take the catalytic material and sell it to a scrappy but the ones around mine stopped buying the material as they have no way of checking if it hasn't been weighted down with non-catalytic material (read sand ect)
  6. Likes justin32 liked this post
  7. #6
    Mar 2010
    Trim : Design
    Engine : 1.9 CDTi
    Quote Originally Posted by justin32 View Post
    Its the main cat but it also has a sensor inside so be carefull. You can see it from the engine end when its romoved.
  8. #7
    Aug 2011
    Basingstoke
    5 Post(s)
    Trim : SRI
    The main cat hasnt. i took it off before when replacing the flexi
  1. Drilling out the cat
    By fewksie in forum Diesel Engine related
    Last Post: 29th September 2018, 17:34
  2. DPF Drilling
    By bafoo in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2013, 15:12
  3. HELP lol, drilling pedals....
    By danBoy in forum Vectra C / Signum Car Chat
    Last Post: 28th February 2010, 09:58
  4. drilling air box
    By winnie2457 in forum Diesel Engine related
    Last Post: 21st February 2010, 14:45
  5. Instead of drilling into the bumper...
    By n_hudson in forum Electrical & ICE (including SatNav)
    Last Post: 10th June 2008, 22:07
