Results 1 to 4 of 4
Thread: A couple of issues
    Aug 2013
    Warrington
    Vehicle : Vectra cdti 120
    Trim : Sri
    Engine : 120
    confused A couple of issues
    I replaced the fuel filter on our cdti 150 a few months ago. Since then there has been a dribble of fuel - I assumed it was from the seal, however it looks to be coming from the quick release connector on top of the filter housing. Any ideas why this would leak?
    On another note, the car has developed a whine from the timing belt end of the engine - no whine at idle, whine increases as revs go up. There is plenty of fluid in the power steering reservoir and the noise does'nt get worse when the wheels are turned. I have put all the electrical items on to see if the alternator is making the noise - it has no effect.
    Car has auto transmission. I am thinking aux belt tensioner and something from the induction side of the engine?
    Apr 2016
    Ipswich
    93 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Year : 2003
    Mileage : 140000
    the fuel leak could be because the quick push connectors seal has gone (only able to get that from vauxhall parts specialists or the dealers parts counter)
    The noise you are getting is probably from the aux. belt or it's tensioner... solution replace belt and tensioner... but the noise could be coming from a roller/guide so i would take slacken the tensioner and check everything the belt touches and replace accordingly...
    Aug 2013
    Warrington
    Trim : Sri
    Engine : 120
    Where is the seal? I can only see a white plastic collar which is a loose fit at the back of the connector.
    Apr 2016
    Ipswich
    93 Post(s)
    Year : 2003
    Mileage : 140000
    It should be on the inside where it pushes onto the pipe from the housing...my dti recently got them replaced I took mine off and found a replacement at a Hydraulics specialist called Pirtek
  1. New member with Sri 1.8 VVT Xp but couple issues I need help with
    By Srimatt in forum Vectra C / Signum Car Chat
    Last Post: 28th August 2019, 11:29
  2. Help! Couple of issues
    By SteveSxi in forum Electrical & ICE (including SatNav)
    Last Post: 23rd May 2014, 10:01
  3. Couple of Issues
    By Marinefish71 in forum Vectra C / Signum Car Chat
    Last Post: 12th November 2013, 23:27
  4. couple little issues
    By pedro88088 in forum Vectra C / Signum Troubleshooting
    Last Post: 8th July 2013, 20:10
  5. couple issues have can along I think
    By marc vectra sri in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd June 2013, 13:24
