Right where to start. the other week the coolant light appeared on my dash. so i stopped and noticed the coolant low. i went to open the bottle and it had pressurised with a load of oil running in with the water. It hadnt gone like mayonnaise either. so i got the car home (needle was just past the 90°c mark although the the hidden menu on the cdc70 navi was reading around 105°C) . i contacted the garage and it was left in.The oil cooler had been leaking onto the exhaust since i bought the car so i assumed it had given up completely. so we replaced the oil cooler and had the engine and coolant system flushed as well as a service also the bolts were tapped as the rocker was weeping due not been tightened enough. anyway i got the car back and it was a rocket ship it had been miss firing due to post car 02 sensor being knackered. but it was on mt way home from work the following day i noticed the neeslw sitting just past the 90°C mark and again the hidden menu itbwas around 105°C again. i got home and it had pressurised the coolant again but there wasnt any oil in it. so i took the car back up to the garage where he tested the coolant to see if thr head gasket was away.he was using the blue liquid stuff on thr coolant bottle . at this point the coolant was pushing up into hi u shapes test tube and thwn it started to suck it all backthe blue liquid too?. its defianlt not the head gasket but we then noticed that the heater was blowing cold and no water was getting to it. so he took the return pipe into coolant bottle and nothjng was coming out. so he diagnosed the water pump. so hes replaces the water pump and flushed the system again but its still pressuring the coolant?
im now at my fed up with it and ive enough on my plate atm thanks to DVA not processing my application for a malfunctioning digi card so im now of the road as its been near 3 weeks . any my thoughts are to possibly it either not being bled properly or the thermostat being knackered but i couldnt see how it would pressurise the system. any help for anyone will be much appreciated
almost for got its z18xer engine in her.
not to mention the ****** PAS pump has gone ffs so ive a second hand unit to fit into it. its defo not the battery etc as it was tested but strange thing is it is intermittently throwing up the abs light too.
