Likes Likes:  2
Results 1 to 8 of 8
Thread: Zafira B z19dth boost issue
    Aug 2014
    Ipswich
    Trim : SRI
    Engine : 2.2
    Default Zafira B z19dth boost issue
    I need some help with a problem I am experiencing.
    Car developed a slight turbo whine and at low rpm/low load. After googling I put this down to a leak at 1 of the gaskets on the turbo. Car was still pulling like a train.
    Then one day taking a drive the car felt very sluggish/laggy (I thought it couldn't been a blocked DPF) and once I got on the dual carriage way I got check engine light and limp mode.
    I am getting fault code P0234-5B Boost Pressure Control Circuit Positive Deviation.
    I did have a brief look under the bonnet but am not sure what to look for. Can't see any obvious damage to hoses/vacuum lines.
    Here is a link for live data recorded to trigger check engine light and limp mode.
    Any advice would be great thanks.
    Sep 2018
    Glasgow
    Clean the map sensor and check the pipes going to the boost control solinoid as well as the solinoid itself.
  3. Likes cheese_za liked this post
  4. #3
    Aug 2014
    Ipswich
    Trim : SRI
    Engine : 2.2
    Quote Originally Posted by davoc220 View Post
    Do you mean MAF sensor? If not, what's the MAP sensor.
    Will check the pipes going to the boost control solenoid. I replaced that about 2 years ago.
  5. #4
    Sep 2018
    Glasgow
    The map sensor is on the inlet manifold, it’s inclined to coke up
  6. Likes cheese_za liked this post
  7. #5
    Aug 2014
    Ipswich
    Trim : SRI
    Engine : 2.2
    Thanks. Will check that now.
    Can I use carb and brake cleaner on it?
  8. #6
    Sep 2018
    Glasgow
    Brake cleaner should be fine, if there’s any deposits on the sensor mesh, use a cotton bud to gently take it off tho
  9. #7
    Aug 2014
    Ipswich
    Trim : SRI
    Engine : 2.2
    I have checked the MAP sensor, it seems fine:
    I removed the boost solenoid. It is not blocked, and it actuates when current is applied to it. Vacuum lines refitting snugly.
    Is the next step turbo removal?
    Also, is the car still ok to drive like this?
  10. #8
    Admin & Membership Manager bigmac's Avatar
    Jul 2008
    Devon
    100 Post(s)
    Vehicle : insignia
    Trim : irmscher
    To me, that map sensor looks dirty
    Irmscher Insignia CDTI 130
  1. Zafira Z22YH Fuel Issue
    By Adamant in forum Engine & Drivetrain
    Last Post: 4th March 2020, 22:02
  2. Z19dth issue
    By new_gen in forum Engine & Drivetrain
    Last Post: 28th July 2018, 21:58
  3. Losing boost Z19DTH
    By nikolat in forum Vectra C / Signum Troubleshooting
    Last Post: 6th June 2018, 06:36
  4. Zafira Z19DTH cutting out
    By cheese_za in forum Engine & Drivetrain
    Last Post: 16th February 2017, 05:15
  5. For Sale: Boost sensor Z19DTH
    By Wilson118 in forum Parts for sale
    Last Post: 15th January 2016, 09:14
