Thread: Z18XER rocker cover
    May 2015
    belfast
    Vehicle : vectra estate
    Trim : sri
    Engine : z19dth
    Mileage : 131k
    Default Z18XER rocker cover
    Hi guys im looking any pointers is possible. I replaced the gasket on the rocker cover today as i noticed a slight weeping/bubbling at the front of the cover when i bought the car never mind the red sealant someone had smeared over it. Any i replaced the gasket and also notices plug 4 was sitting in a pool of oil as well as a little oil i plug 2 and 4 so it turns out the pcv is knackered so ive ordered the replacement diaphram off ebay. But when i was replacing the rocker cover i noticed 2-3 of the bolts wont go tight. I didnt take it off to investigate but looking to see if anyone has encounterdd this problem before and if its a case of replace the bolts or will i need to tap the threads ??
    May 2015
    belfast
    Trim : sri
    Engine : z19dth
    Mileage : 131k
    Right guys i got round to fitting the replacement PCV diaphram this afternoon (between sleep and nightshift ) and i foumd when removing the old one there wasnt any damage to the diaphram?? Any way i replaced it wifh the new one and fitted all back together. This is when i eventually inspected the rocker cover bolts. A couple of the threads have some sort of damage ( nothing of great concern) and the receiving threads on the head look a little damaged so im wondering if the bolts arent giving a good clamping force would it still affect the preasure in the head? Just im still getting a sucking effect through oil cap and a very faint one through the dipstick. When removing the dipstick before and after i done the PCV it was still running rough . I also added some more oil to the car and tgh rattle around the vvt solenoids disappeared as well as the roughness when removing the dipstick. Im new to the petrol engine side of vectras as ive always had the 1.9 cdti. So any info ive gathered its by any info i could find on here. So any help much appreciated guys i know ive still the 02 sensor to do post cat but im still getting between 28-30 mpg with a mixture of easy driving and thrashing. Also to mention i noticed that theres a slight bit of play in the flap on thr throttle body as if its not 100% closed
    VIP-Member Jon1796's Avatar
    Sep 2015
    Norwich
    6 Post(s)
    Vehicle : Vectra VXR
    Trim : VXR
    Engine : 28NEH
    Year : 07
    Mileage : 70,500
    https://www.vectra-c.com/forum/showt...i-issues/page3
    also think neighbour had similar problem with vacuum on Zafira replaced rocker and cleaned out breather pipes down the back from cover.
    Nov 2013
    suffolk
    Vehicle : vectra 2007
    Trim : sri
    Engine : z18xer
    Make sure you get the correct Gaskit, if it's cheaper than £20, it's no good.
  1. Z18XER Rocker gasket to seal or not?
    By racingmars in forum Engine & Drivetrain
    Last Post: 5th May 2020, 11:21
  2. Never have to buy a rocker cover again!!!!!!!
    By Gary5661 in forum Vectra C / Signum Car Chat
    Last Post: 25th March 2019, 20:57
  3. Z18xer 1.8vvt sludge discovered after rocker/camshaft cover removal.
    By john is200sport in forum Vectra C / Signum Car Chat
    Last Post: 22nd December 2017, 19:34
  4. Z18xer vvt rocker cover gasket
    By stephengreen1980 in forum Engine & Drivetrain
    Last Post: 17th December 2013, 12:37
  5. 2.2 Rocker cover (types) - Intake cover removal
    By vectrasri03 in forum Vectra C / Signum Car Chat
    Last Post: 1st April 2006, 20:27
