Hi Insignia 2.0 cdti 2010/60 if I disconnect battery will I lose radio code on this model? Thanks
No .
Agreed - No.
All Insignia units are okay in this respect.
All cars after approx October 2004 should be perfectly fine if you disconnect the battery.
Only the earlier Vectra-C units - CDR2005, CCR2006 and such like need the code inputting after disconnection of the battery.
Thank you all for your help Rew
As said, no.
You will however had to reprogram the one touch elecy windows.
It should tell you how to do this in the speedo display message area. But it's basically fully open the windows, then close them and keep your fingers on the close button for a few seconds.
