Thread: Jacking Vectra C . Advice Needed.
    Jun 2009
    Middlesex
    Default Jacking Vectra C . Advice Needed.
    If jacking my Vectra C at the front, please can anyone advice where to correctly position a trolley jack under the front of the car to eventually lift both sides of the vehicle to then where to position the Axle Stands to support the front of the car. Don't know if anyone has a photo as i suspect to describe a exact position would be difficult.
    Your help much appreciated.
    Sent from my SM-J510FN using Tapatalk
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    24 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    If you get on your hands and knees you will see an inverted triangle/Arrow,on the sill. This is the jacking point.
    Where you put the axle stands is dependant upon where you need to work/access etc.
    Midlands - Vxr Owning Dick Dog_Book's Avatar
    Oct 2013
    Derby
    289 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Jack it on the jacking points.
    Teapot Tuned 255/300
    Tech2 & MDI diagnostics + SPS
    12 Post(s)
    Avoid any suspension arms, as you will bend them. Likewise, don't jack on the lip of the sill where the default car jack would normally be fixed.
    Not sure if this is any help? I can't remember where I obtained it from.
    Oct 2013
    Derby
    289 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    It’s also in the handbook.
    Jun 2009
    Middlesex
    Diagram above a great help. I can now see where i can safely lift the car. Only slight problem I've found is where I'm lifting the car with my Trolley Jack is also the same place i guess i need to position my Axle Stand. Thought about positioning Axle Stand and supporting weight of car at the manufactures "Arrow" marking on the forward & Aft parts on the sill where you would normally put the boot jack to change a wheel, but it's cup holder is only plastic and would not except an Axle Stand
    Please advise me if there is a way around this as i could be missing something here.
  1. Vectra CDTI 150 Front Shocks needed .. Advice needed
    By aps in forum Vectra C / Signum Troubleshooting
    Last Post: 20th September 2015, 21:35
  2. Vectra CDTI 150 Front Shocks needed .. Advice needed
    By aps in forum Handling & Braking
    Last Post: 20th September 2015, 19:34
  3. not a vectra but advice needed
    By brookie1 in forum Diesel Engine related
    Last Post: 14th January 2015, 23:00
  4. vectra c 2.2 advice needed
    By davidlewis24 in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2009, 19:52
