Thread: Misfire insignia 1.8 petrol cylinder 4
    Regular Member mrk's Avatar
    Vehicle : vectra hatchback
    Trim : improving
    Engine : 1.9cdti mas remap
    Year : 06
    Default Misfire insignia 1.8 petrol cylinder 4
    A lad at work has read codes and got this fault. He's replaced plugs and coil but it's still the same. Any ideas?
    13 Post(s)
    What did he use to extract the code(s)?
    Post the code here so it can be cross referenced as to being the correct diagnosis.
    Trim : improving
    Year : 06
    He's going to check. Thanks
    13 Post(s)
    Another thought, (and sorry if it's sounds like I'm teaching grandmother to suck eggs)
    He did identify cylinder 4 correctly and not cylinder 1 by mistake? Cylinder 4 is usually furthest from the cam belt on a 4 cylinder engine.
    Trim : improving
    Year : 06
    P0004 has done a compression test 160psi on cylinders 1 and 2 nothing on cylinders 3 and 4.
    Trim : improving
    Year : 06
    P0004 code
    13 Post(s)
    Quote Originally Posted by mrk View Post
    Did he then add a small amount of oil to see if there was an increase in compression? If there wasn't, then one or more valves could be leaking, or a crack in the block or head.
  1. Cylinder misfire 1, please help.
    By jpj1_358 in forum Engine & Drivetrain
    Last Post: 7th January 2016, 21:46
  2. HELP Misfire Cylinder 4
    By Coppen in forum Engine & Drivetrain
    Last Post: 7th December 2015, 22:29
  3. misfire on cylinder 2 + 3
    By simon.groom in forum Engine & Drivetrain
    Last Post: 21st February 2014, 00:34
  4. misfire on cylinder no 3
    By WRed in forum Vectra C / Signum Troubleshooting
    Last Post: 24th January 2011, 00:50
  5. Misfire on cylinder 4
    By gavman in forum Engine & Drivetrain
    Last Post: 29th June 2009, 21:58
https:www.vectra-c.comforumshowthread.php235777-Misfire-insignia-1-8-petrol-cylinder-4
insignia 1.8 misfire
