314mm Calipers how do you tell which is N/S or O/S?
Hi lads I need some info please
I have just bought a pair of 314mm callipers but I am unsure which is NS and wihich is OS they look identical apart from the bleed nipple locations.
Also will my standard 285mm brake hoses fit and work on these callipers or do I need to get different hoses for them?.
Also am I right in thinking the standard rear 278mm callipers are the same as the 292mm callipers but just different carriers and vented discs with shallower pad material?,I could be being stupid here but the callipers look to be no different?
Nipples should be hard and pointy up I think
Post Thanks / Like - 0 Thanks, 2 Likes
Originally Posted by
Jon1796
Nipples should be hard and pointy up I think ��
I couldn’t agree more 😂
nismo128
They will be fine.
nismo128
No, pads are the same, 292mm caliper is wider.
Kristian
68 Diplomat-A 46S
95 Vectra-A C20NE
07 Vectra-C Z19DTH
Bleed nipple should be at the top when fitted ......
Thank you all for your replies
21st March 2020, 20:57
#8
21st March 2020, 20:58
#9
Was easy to fit them if anyone else is contemplating this
21st March 2020, 20:59
#10
I removed the heat shield/disc backing plate completely as didn’t want to get the grinder out with a brake fluid puddle on the floor lol
