Thread: xenon headlight upgrades
    SUFFOLK
    Default xenon headlight upgrades
    A question for those who have done the HID upgrades.
    I'm in the process of fitting HID headlights to an 04 vectra using green Growler's how to wiring. Unlike others on this forum I've opted to fit the factory xenon vauxhall headlights and modify the internal wiring (so that you end up with the correct lens and reflectors etc)
    Bulb check works fine and lights power up ok. However, i've noticed that while they don't flicker (using 3200uF worth of capacitors), there is a very slight high pitched transformer whine like noise from the ballast/starter pack.
    Is this normal?
    Regular Member Neil's Avatar
    Feb 2007
    The pool
    My previous car had factory fit Xenons. When you switched the lights on, if you where at the front of the car it gave a high pitched whining sound that disappeared as they got hot!
    Melbourne, Australia
    dieselvec1, I'd like to hear more about your setup - have you fitted the self-levelling?
    SUFFOLK
    Quote Originally Posted by Neil View Post
    That kind of makes sense. I'll have to let them warm up at the weekend and see if the noise stops. I haven't actaully swapped the lights over yet just connected them to the wiring harness for testing.
    SUFFOLK
    Quote Originally Posted by stevedee3 View Post
    I've taken the standard xenon headlights and modified the wiring so that they are compatible with the non-xenon wiring. Essentially you take green growler's wiring and cut the blast connections inside the headlight and then run a secondary earth cable.(ie no changes to the original loom if I need to swap back).
    The self-leveling could in theory be fitted but would probably require a scrapped car to take bits of the harness off which are missing.
    The only thing I haven't yet done is sorted out the leveling motor. The xenons have a 4 wiring motor as opposed to 3 wiring although the headlight fitting are the same. I will either leave the 4 wire motor in place if I can get it to work or swap them for the 3 wire ones on my existing headlights.
    Regular Member pricey's Avatar
    Dewsbury, West Yorkshire
    I'm been a bit nosey here, but how much are the headlight units if you don't mind me asking?
    Thanks dieselvec1.
    SUFFOLK
    Quote Originally Posted by pricey View Post
    They work out at about £450 each using New Vauxhall bits or about £180 for a pair from ebay or a scrapyard (the route I used).
    If you can find them on via ebay etc the price isn't bad considering you end up with the near factory spec.
    Have opted to replace the standard blubs with 6K ones from HIDS though.
    Will probably fit bank holiday weekend post how 2 at some point.
  1. Pre facelift headlight upgrades
    By dizzy in forum Electrical & ICE (including SatNav)
    Last Post: 13th January 2009, 12:19
  2. O/S/F VXR Xenon headlight
    By glenboy in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 23rd November 2008, 23:49
  3. xenon headlight
    By ADAM123 in forum Parts for sale
    Last Post: 5th October 2008, 20:57
  4. Xenon Headlight Upgrades
    By dieselvec1 in forum Electrical & ICE (including SatNav)
    Last Post: 28th September 2007, 23:22
  5. Headlight Bulb Upgrades
    By dave16v in forum Vectra C / Signum Car Chat
    Last Post: 6th July 2007, 01:09
