Thanks Thanks:  1
Likes Likes:  7
Thread: CID display low brightness - Solution
    Feb 2020
    Bulgaria
    Vehicle : Opel
    Trim : Vectra C
    Engine : Z19DT
    Default CID display low brightness - Solution
    Hello,
    As a many of you with color info display I also have issue with the low brightness. It's almost impossible to see it during the day. I decide to change this. With the help of this forum i understand for the ccfl backlight of the display. I make some googling and found this:
    The display exact model is 5.8" TFT-panel Toshiba LTA058B110D
    The exact model of ccfl lamp is:
    CCFL special 135-82-135mm x 2.6mm (U x Ø) white.
    I order it from Germany and waiting to receive it.
    I will post pictures of the replace process and result.
    I can post link to the website here.
    Best regards
    Administrator plasma's Avatar
    On the Forum
    572 Post(s)
    Engine : 150
    Mileage : 74000
    Also note that I have come across this and was the LCD itself, not the CCFL
    Feb 2020
    Bulgaria
    Vehicle : Opel
    Trim : Vectra C
    Engine : Z19DT
    LCD display in my case it's not broken. I see it during the day and night. Just not so bright.
    Regular Member Jon1796's Avatar
    Sep 2015
    Norwich
    27 Post(s)
    Vehicle : Vectra VXR x2
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Mileage : 75,000
    If you’re still got oem radio what does it show for lcd in settings hidden screen.
    I know there’s a display test on cid with t2 can’t remember if you can adjust contrast on it though???
    Feb 2020
    Bulgaria
    Vehicle : Opel
    Trim : Vectra C
    Engine : Z19DT
    Job done.
    The result is 100% positive. Now I can see the screen in daylight.
  6. Likes Dog_Book, Woody, bigmac, watchman, Teapot liked this post
  7. #6
    Regular Member Teapot's Avatar
    woodbridge, suffolk
    278 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    Nice find, I had one go dim before and ended up replacing the whole CID.
  8. #7
    Aug 2016
    Croatia
    Trim : Cosmo
    Mileage : 100000
    @Nedra do you have picture of CID working?
  9. #8
    Feb 2020
    Bulgaria
    Vehicle : Opel
    Trim : Vectra C
    Engine : Z19DT
    https://imgur.com/RIdCHwB
  10. #9
    Feb 2020
    Bulgaria
    Vehicle : Opel
    Trim : Vectra C
    Engine : Z19DT
    Hello again,
    can you help, when I open the driver door the BC turn on. Only BC function. Which is the settings for stop this?
    I want to turn on only on ignition.
  11. #10
    Full Member Robsey's Avatar
    North East Cheshire
    30 Post(s)
    Trim : Energy
    Mileage : 150,000
    I have sent a reply by pm.
    The display will always power up when -
    1 - You unlock the doors.
    2 - Open the driver's door.
    3 - Switch on the side-lights.
    As far as I am aware, there is no facility in normal programming to get the display to ignore the "interior lights on" signal from the BCM.
    I have suggested in my pm reply, to briefly pull fuse 17 then lock and unlock the doors to see if this disables the display without losing volatile memories.
    Then refit the fuse to verify that the time etc has not been lost.
    If the time has not been lost, then you could divert the feed to display pin 5 to an ignition live supply via a 20 amp fuse.
    If it does not work, try the same test, but this time, pulling fuse 1.
    If this now works as planned, then connect display pin 3 to an ignition live supply.
    If neither method works, then you are stuck with the display powering up as described.
    The only other way to kill the board computer at unlocking etc, is to disable the board computer in the display code index.
    This time, rather than board computer, you will get the date and time on the display when you unlock the car.
    Sadly - set like this, you will not get the board computer to display even with the ignition on.
  12. Thanks Nedra thanked for this post
    Likes Nedra, northpole liked this post
  1. colour screen no brightness adj
    By paul wingnut in forum Electrical & ICE (including SatNav)
    Last Post: 29th April 2015, 23:34
  2. CD70 display brightness
    By NeiltSRi in forum Vectra C / Signum Car Chat
    Last Post: 13th January 2014, 14:48
  3. Display Brightness.. Can it be adjusted
    By Sigmacca in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2012, 06:14
  4. Headlight brightness tip
    By Teapot in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2011, 12:18
  5. Sat Nav brightness
    By 111 in forum Vectra C / Signum Car Chat
    Last Post: 7th November 2010, 20:55
https:www.vectra-c.comforumshowthread.php235722-CID-display-low-brightness-Solution
https:www.vectra-c.comforumshowthread.php235722-CID-display-low-brightness-Solutionpage2
vectra-c.com
