Thread: Issues starting
    Jan 2019
    UK
    Engine : 1.9 TDi
    Default Issues starting
    Hi all
    Iíve got a 2008 veccy c Sri CDti and had the fuel filter replaced a couple of weeks ago. Since then, my consumption is terrible and this morning she had issues starting. Was like the battery was flat.
    I heard a rumour that changing the fuel filter can damage the starter motor. Is this true? And if so how easy is it to replace the starter without wrecking the car completely
    Sent from my iPhone using Tapatalk
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    48 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    The only.reason for it to damage the starter is because there is air in the system and you didn't top the filter up.... meaning the system has to self bleed... this in turn causes the car to have not enough fuel at starting, making the starter work harder...
    My advise top up the filter with either diesel or an injector cleaner... and with top up I mean fill it to the brim.
    Jan 2019
    UK
    Engine : 1.9 TDi
    I didnít replace it myself, it was done by a garage
    How / where do I top it up? It was done about 2 weeks ago
    The YouTube tutorials show the one near the fuel tank, but the one which was done was under the bonnet
    Apr 2016
    Ipswich
    48 Post(s)
    Mileage : 140000
    If a garage has done it than it should've been done right... the cdti's do self bleed and if that was done 2 weeks ago it should be done now. Also it is the one under the bonnet that needs to be filled completely... but like insaid before if a garage has done it than it should be fine.... maybe you need new glow plugs, but if it is hard to start when the engine is warm also than it deffo isn't that and maybe you need to replace the starter motor... they last for a certain time not for ever.
    Jan 2019
    UK
    Engine : 1.9 TDi
    So it happened again tonight
    Started fine, drive 2 mins to shop then wouldnít start. Sounded like the battery was dead
    Switched off, position 3 on ignition until whirring from fuel tank / pump stopped then started fine
    Iím thinking this is a cheap fix??!!??
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    24 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    WAs the car doing this BEFORE it went into the garage?
    Apr 2016
    Ipswich
    48 Post(s)
    Mileage : 140000
    so you waited for the intank fuelpump to built up the pressure? .... bring it back to the garage that changed the filter and tell them they forgot to bleed the system and because of that you are now experiencing starting problems...
    Sep 2014
    uk
    Vehicle : vectra C sri estate auto+ hatchback auto x 2
    Trim : est sri auto hatch design auto x 2
    Engine : 1.9 cdti 150 x 3
    Year : 08/07
    [QUOTE=Nodral;2523138]Hi all
    I’ve got a 2008 veccy c Sri CDti and had the fuel filter replaced a couple of weeks ago. Since then, my consumption is terrible and this morning she had issues starting. Was like the battery was flat.
    So i assumeing yours is a 150 cdti.
    1 Changeing the fuel filter cannot damage the starter motor ,the filter lives sort of over the starter motor but it's sealed so even if you drench it in fuel it should not do it any harm.
    2 ( Haynes manual)To bleed the fuel filter you prime it by switching on the ignition 3 times for approximatly 15 seconds each time ,then operate the starter for a maximum of 30 seconds,if the engine does not start within this time wait 5 seconds and repeat the procedure. When the engine starts run it at fast idle speed for a minute or so to purge any trapped air.After this time the engine should idle smootly at a constant speed. If the engine idles roughly then there is still some trapped air in the fuel system. Increase engine speed again for another minute or so then allow it to idle.Repete this prosedure as nessessary until the engine runs smootly.
    In my experience on changing loads of these filters i do the 3x 15 seconds ignition on/offs and start the engine and fast idle for 10 seconds or so and NEVER had a problem.
    Why your fuel consumption is terrible i have no idea.
    I've recently replaced a starter motor on one of our cdti's as it was getting harder to start and on stripping the old s/motor one of the bushes was BADLY worn.The car now starts great with the replacement starter motor.
  1. starting issues
    By vectrani in forum Engine & Drivetrain
    Last Post: 17th June 2015, 10:54
  2. starting issues
    By paul515 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd May 2015, 18:46
  3. starting issues
    By kylewareing in forum Engine & Drivetrain
    Last Post: 17th April 2013, 17:40
  4. starting issues
    By marc vectra sri in forum Vectra C / Signum Troubleshooting
    Last Post: 26th October 2012, 07:57
  5. Starting issues...
    By jones5n in forum Engine & Drivetrain
    Last Post: 9th October 2011, 18:29
