Likes Likes:  3
Thread: Engine undertray 1.6 diesel
    Regular Member paul-west-76's Avatar
    Feb 2011
    wolverhampton
    Vehicle : Insignia tourer 1.6 elite
    Trim : elite
    Engine : 1.6 cdti
    Year : 2015
    Mileage : 104000
    Default Engine undertray 1.6 diesel
    Hello folks, I’ve recently purchased an insignia tourer, it’s 2015 1.6 diesel ecoflex, I noticed that their is no undertray fitted below the engine, after looking around and speaking to a few people I’m none the wiser as to one should be fitted, some say yes and some say no, any ideas?? Thanks in advance.
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    93 Post(s)
    Vehicle : Vectra C Saloon( sadly died at age 20 due to a hart attack)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    go to www.7zap.com select catalogues, select vauxhall, fill in your vin and check if the part is available for your car... that would be the only way to actually check it other than going to the dealer and asking them to check your vin for it.
  3. Likes paul-west-76 liked this post
  4. #3
    Jul 2018
    BIRMINGHAM
    Trim : Life
    Engine : Z19DT
    Year : 07
    There's no requirement to have one fitted and as you've experienced, there are 2 camps in support and against them.
    For:
    Aerodynamics (a negligible amount)
    Stops any leaks dripping on your drive
    Against:
    Prevents easy access to engine
    Stops any leaks dripping on your drive so you don't know if you've got any leaks
  5. Likes RBH, paul-west-76 liked this post
  6. #4
    VIP-Member
    Sep 2020
    Bilston
    Vehicle : Vauxhall Insignia
    Trim : Hatchback
    Engine : 2.0
    Year : 14
    Don’t forget under tray keep engine from direct water splash
    Sent from my iPhone using Tapatalk Pro
  7. #5
    Midlands - Vxr Owning Dick Dog_Book's Avatar
    Oct 2013
    Derby
    340 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Nothing to do with water splash otherwise all engines would have them, it’s for drive by tests when the do emissions and noise testing.
    Teapot Tuned 255/300
    Tech2 & MDI diagnostics + SPS
  8. #6
    Apr 2016
    Ipswich
    93 Post(s)
    Mileage : 140000
    Quote Originally Posted by Dog_Book View Post
    This and it helps keep the bay cleaner... but that is all if they really wanted to close the engine bay of completely they would've done so... my vectra doesn't have it either for the simple reason it was damaged , kept hanging off on one side so i removed it and the frame to it... car is a little louder (you can hear the engine noises better) and when i change gear you can hear the gear selector working, got used to it.... but eventually i will get another one to bring the peace and quiet back to my DTI as it's already louder than most diesel engines by design.
  1. For Sale: Engine Undertray from cdti
    By rockafella8587 in forum Parts for sale
    Last Post: 5th June 2013, 12:23
  2. engine undertray
    By mrk in forum Vectra C / Signum Car Chat
    Last Post: 29th December 2011, 12:13
  3. DTI engine undertray
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2011, 19:14
  4. Engine Undertray
    By shaun260589 in forum Vectra C / Signum Car Chat
    Last Post: 8th April 2010, 20:59
