Thread: Z22YH rattling sound and no power
    Jan 2014
    Sweden
    Trim : 2.2
    Engine : 2.2
    Default Z22YH rattling sound and no power
    Vectra C 2.2 2006
    The engine have had problem with rumbeling idle for some time but no codes when I have checked with Opcom. I have cleaned the Throttle body but no change. When drivning the engine have worked perfect.
    Last week when Instarted the engine have a rattling sound and now have lack of power, but still no codes in the Opcom and no warning light. The car have Run 20.000 km about 12.428 miles. What can be the problem? Is the lifters stuck
    Regular Member Daywalker's Avatar
    Aug 2007
    Mitkunai k, Kaunas raj
    Vehicle : VW Jetta
    Trim : SE
    Engine : 1.4 TSii
    Year : 2017
    Probably chain stretch
    Regular Member skidmark1's Avatar
    Sep 2010
    cornwall
    Vehicle : 2.2 Direct
    Trim : SRI
    Engine : YH 2.2 petrol
    Mileage : 106000
    timing chain, replaced mine along with the balance chain with sprockets and the uprated tensioner which is used in the 2.0L net engine
    Jan 2014
    Sweden
    Trim : 2.2
    Engine : 2.2
    Damn, this is nothing you can do yourself without special tools, right?
    Sep 2010
    cornwall
    Trim : SRI
    Mileage : 106000
    cam locking kit is a must
    Jan 2014
    Sweden
    Trim : 2.2
    Engine : 2.2
    Do you change the water pump when doing the chains?
    Sep 2010
    cornwall
    Trim : SRI
    Mileage : 106000
    no I was told it already had a pump change but also I was told the cam chain had already been done which in part was true just the chain, no sprockets of guides or tensioners, thats what you get from a garage job under warranty so I made sure it was a full kit fitted
  1. Rattling sound from flywheel/clutch?
    By BaconSarnie in forum Engine & Drivetrain
    Last Post: 23rd August 2016, 00:40
  2. Z19DTH No Power Below 3krpm Sounds Like Turbo Rattling
    By BigDaveDJ90 in forum Engine & Drivetrain
    Last Post: 21st May 2015, 19:37
  3. Rattling sound. Sounds like a coke can.
    By BigWilko in forum Vectra C / Signum Troubleshooting
    Last Post: 31st May 2013, 21:59
  4. Power steering noise, rattling and moody fuel flap.....
    By johns159 in forum Insignia car chat
    Last Post: 31st March 2010, 13:48
  5. rattling sound
    By kevin hunter in forum Engine & Drivetrain
    Last Post: 21st April 2008, 21:44
