Results 1 to 3 of 3
Thread: Little pipe
    Jan 2019
    UK
    Vehicle : Vectra C
    Engine : 1.9 TDi
    Year : 2008
    Default Little pipe
    So Iím no mechanic, but Iíve just changed the drivers side headlight bulbs on my 2008 veccy estate.
    As Iím sure you all know I had to remove the air filter housing to gain access.
    Whatís the small rubber tube for at the bottom? Itís about 3/4 inch. Came out easy enough, but virtually impossible to get back on
    Apr 2016
    Ipswich
    52 Post(s)
    Vehicle : Vectra C
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Year : 2003
    Mileage : 140000
    It's a drain to direct any collected moisture/water away from it.
    Sep 2014
    uk
    Engine : 1.9 cdti 150 x 3
    Year : 08/07
    Yes it's such a pita that i now don't bother trying to refit it.
  1. Which boost vacuum pipe?? (WASTE GATE ACTUATOR PIPE 55204300)
    By russy47 in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd November 2018, 00:03
  2. Brake servo pipe Help (Plastic Pipe)
    By Mark2.2 in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2014, 15:41
  3. EGR offtake pipe (turbo to egr cooler pipe) - Part# ?
    By jonnyaykroyd in forum Engine & Drivetrain
    Last Post: 3rd March 2013, 01:29
