Thanks Thanks:  1
Results 1 to 10 of 19
Thread: Half an inch lower on off side and squeaking over bumps
    Apr 2019
    England
    Vehicle : Vauxhall Vectra
    Trim : C
    Engine : Isuzu 3.0 TD
    Year : 54
    Default Half an inch lower on off side and squeaking over bumps
    Hello fellow vectra victims!
    So it is the season of debt. My vectra c (54 plate) has been knocking for a month or so, and I was waiting for the MOT in jan to get it sorted. However it has now started a really sharp metallic squeak going over very small bumps today (does not sound healthy at all) and the off side is half an inch lower than the near side. Tyre pressures arenít the issue. Ive had a quick look under the car without jacking it up and canít see anything obvious on the lower arm. Whatís the most likely culprit?
    Thanks in advance!
    Sent from my iPhone using Tapatalk
    Sep 2014
    uk
    Vehicle : vectra C sri estate auto+ hatchback auto x 2
    Trim : est sri auto hatch design auto x 2
    Engine : 1.9 cdti 150 x 3
    Year : 08/07
    A spring .
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    45 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    Whs
    Regular Member Daywalker's Avatar
    Aug 2007
    Virbaliskiu km, Kaunas raj
    Vehicle : Astra Sports Tourer
    Trim : active
    Engine : 1.7cdti
    snapped spring probably
    Sep 2014
    uk
    Year : 08/07
    Yes a spring is a likely culprit.
    Apr 2019
    England
    Trim : C
    Year : 54
    Iíve checked the spring. Doesnít seemed snapped anywhere?
    Here are some photos first two is the effected side, second two is the non effected side. Seems like part of the cover is rolled back with some oil there. The oil was fairly fresh (wipes onto tissue) thanks again!
    Apr 2019
    England
    Trim : C
    Year : 54
    Quote Originally Posted by northpole View Post
    Whs
    Sorry but whatís a whs?
    Apr 2016
    Ipswich
    45 Post(s)
    Mileage : 140000
    It's short for: what he said...
    And that deffo is a broken spring mate... you might not be able to see it without removing the shock absorber on that side...
    Sep 2014
    uk
    Year : 08/07
    I wondered what whs was lol. Take a very close look at the springs it is very easy to miss as iv'e found out .The broken end may be lying on a road somewhere. The leaking drive shaft gaiter is a mot fail so best get it fixed.
    12 Post(s)
    The squeak is most probably a dry antiroll bar rubber bush. Only time mine didn't squeak was when it rained.
    regarding whs, if you put it inside the colon symbols, then it becomes which makes it more obvious.
  1. Front of car, one side lower than other......
    By rob1981 in forum Handling & Braking
    Last Post: 29th August 2013, 13:10
  2. one side lower
    By marc vectra sri in forum Suspension, Wheels & Brakes
    Last Post: 13th August 2013, 20:28
  3. Banging and squeaking from driver's side (RHD Signum)
    By Celes in forum Suspension, Wheels & Brakes
    Last Post: 3rd January 2010, 22:45
  4. vxr lower spoiler with sri side skirt?
    By topgun in forum Styling
    Last Post: 16th July 2009, 14:42
  5. Squeaking From Front Drivers Side
    By Stephen S in forum General Chat
    Last Post: 16th June 2009, 21:20
