Thread: Does a manual Z22SE engine fit into a automatic model???
    Oct 2013
    Leeds
    Vehicle : Vectra Estate 2.2 SRI AUTO
    Trim : SRI
    Engine : 2.2i direct
    Mileage : 22000
    Default Does a manual Z22SE engine fit into a automatic model???
    Another post to my previous one searching for a replacement engine.
    I've seen a z22se vect B engine from a manual car and wonder if would fit my automatic model?? What changes would be required if any?
    Thanks in advance.
    Keith
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    45 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    Engine might be the same (check the engine codes, they need to be exactly the same) but the position of the starter motor needs to be checked... also you won't need the flywheel that usually comes with the engine as your autobox will need to be connected up with it's torque converter and it's starter...
    Oct 2013
    Leeds
    Trim : SRI
    Mileage : 22000
    Thanks Northpole,
    engine codes are the same both z22yh (not se) as in description. I would likely be buying a replacement engine unseen in person (I've seen one for sale with a video showing it running), due to location and other than asking seller, the position of the starter motor. Do you mean checking for condition or for positioning?
    Apr 2016
    Ipswich
    45 Post(s)
    Mileage : 140000
    Position... it could be located in a different area. So if I was you I would look where the one is on your engine and than check it with his... if they are in the same spot than you can get the replacement engine
    Oct 2013
    Leeds
    Trim : SRI
    Mileage : 22000
    I'll get the positions on both engines checked, thanks. RE removing the flywheel on the manual, will a flex plate or something be needed in its place?
    Apr 2016
    Ipswich
    45 Post(s)
    Mileage : 140000
    Quote Originally Posted by junklunacy View Post
    Nope all you need is on your old engine the mechanic that is doing the swap should know what to swap over
    Apr 2008
    West Yorkshire
    Keith, have you tried dixons vauxhall spares?
    http://dixonsvauxhallspares.co.uk/
  1. automatic or manual whats less problematic
    By lesron in forum Engine & Drivetrain
    Last Post: 17th April 2015, 08:01
  2. Automatic to manual conversion on a 3.2 Veccy?
    By tbclose1992 in forum Petrol Engine related
    Last Post: 4th April 2014, 15:34
  3. vectra 2006 z22se automatic oil
    By menachem.mnm in forum Engine & Drivetrain
    Last Post: 24th March 2013, 11:53
  4. Vectra C 2003 - 2.2 Liter Petrol (Z22SE): Automatic Gearbox Oil
    By Tigra16V in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2013, 14:14
  5. Manual (DMF) v automatic gearboxs
    By Readster in forum Vectra C / Signum Car Chat
    Last Post: 25th March 2010, 16:18
