Likes Likes:  2
Results 1 to 10 of 13
Thread: pcv valve on 1.8 16v z18xe vec
    Mar 2017
    newcastle
    Vehicle : Insignia
    Trim : Exclusiv
    Engine : 1.8 vvt
    Mileage : 90000
    Default pcv valve on 1.8 16v z18xe vec
    hi folks, just a quickie, does my engine have a pcv valve? z18xe 1.8 16v non vvt vectra c preface 05(2005)
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    93 Post(s)
    Vehicle : Vectra C Saloon( sadly died at age 20 due to a hart attack)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    it should have it as all ICE engines have crank ventilation....
    watch this video
    https://www.youtube.com/watch?v=LTBKtkP9jsQ
    Mar 2017
    newcastle
    Vehicle : Insignia
    Trim : Exclusiv
    Engine : 1.8 vvt
    Mileage : 90000
    is the pcv valve just a ventilation hole from rocker cover? as previously earlier in the year i cleaned the rocker cover and new gasket, and changed throttle body. never seen any valve. not sure what im even looking for.
    Apr 2016
    Ipswich
    93 Post(s)
    Mileage : 140000
    if you watch that video the guy pulls of a part that looks like a disk connected to a pipe... that is the complete housing where the pcv valve is located... the inside of it can perish over the years causing problems.... and that is the part you need to replace... and yes it is connected to the cover....you see him replacing it at somewhere around 2:28 in the video
  5. Likes LewisMHarold liked this post
  6. #5
    Mar 2017
    newcastle
    Vehicle : Insignia
    Trim : Exclusiv
    Engine : 1.8 vvt
    Mileage : 90000
    nothing like that in my rocker cover. mine was empty with two U shaped pipes and 2 breather holes on outer cover.
  7. #6
    Mar 2017
    newcastle
    Vehicle : Insignia
    Trim : Exclusiv
    Engine : 1.8 vvt
    Mileage : 90000
    well update on me vec. its still in surgery and in bits/ no sign of a gearbox yet/ but frame is off with rack and gearbox out
  8. #7
    Apr 2016
    Ipswich
    93 Post(s)
    Mileage : 140000
    Quote Originally Posted by pauluk49 View Post
    Than some has gutted it... I did that to help put my neighbour, and guess what? He bought a new cover with the proper pcv valve..hunting went away.
  9. #8
    Dec 2010
    London
    8 Post(s)
    Vehicle : Hyundai Ioniq Hybrid
    Trim : Premium SE
    Engine : 1.6 with 32KW motor
    Quote Originally Posted by northpole View Post
    The xe is a different engine and just have the two pipes that come out of cover and into throttle body the smaller one of which has a 1mm bore in throttle body which gets clogged up and causes idle issues.
    PS this thread is over two years old and the OP has an insignia now with the xer engine in.
  10. #9
    Apr 2016
    Ipswich
    93 Post(s)
    Mileage : 140000
    Well not my mistake as I thought he was on about the xer engine not the xe. Ig differences as the xe isn't a vvt. So completely different head and setup of the valve cover.
  11. #10
    Dec 2010
    London
    8 Post(s)
    Trim : Premium SE
    Totally different engines xe first came out in Astra g and Vec b water pump driven off cambelt xer introduced in 2006 for tighter emissions which is why they run hotter and water pump runs off aux belt nothing interchangable.
  1. Need help with Z18xe
    By Big jay in forum Vectra C / Signum Car Chat
    Last Post: 1st September 2019, 15:35
  2. Z18XE EGR Valve
    By urbis in forum Engine & Drivetrain
    Last Post: 13th April 2016, 08:53
  3. Replies: 1
    Last Post: 22nd February 2013, 23:44
  4. Z18XE using oil...
    By danBoy in forum Engine & Drivetrain
    Last Post: 24th April 2010, 10:41
  5. Does the Z18XE have an EGR valve?
    By silent_bob in forum Engine & Drivetrain
    Last Post: 18th March 2009, 11:31
https:www.vectra-c.comforumshowthread.php235484-pcv-valve-on-1-8-16v-z18xe-vec
z18xe pvc crankcase vent systempcv valve opel 1.8
