Results 1 to 10 of 26
Thread: upgrade to colour screen
    May 2007
    Melbourne, Australia
    confused upgrade to colour screen
    Hey all...just came across this site from using OpelAus in Australia.
    I have a 2005 Vectra 3.2 V6 with the yellow screen using the CD70. I wanna upgrade it to the colour screen that the sat nav system uses in Europe.
    Does anyone know if this is compatible and how easy/expensive this would be to do for someone who has no idea?!
    Cheers....
    Wirral / ellesmere port
    12 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    HI M8
    yeah its easy to do,well thats wot i ave been told i also have a fellow member
    on here coming over tomoz to get the mono display changed and tech2`d to
    the colour display so i`ll let you know how it goes,as for cost wise then it
    probably cost you just for the programming of it.
    Regular Member 3.2_V6_VXR's Avatar
    S.Wales, Nr Swansea
    Quote Originally Posted by Andyvec View Post
    HI M8
    im interested in doing this andy, can you keep me updated on that progress
    12 Post(s)
    Trim : elite
    Year : 2011
    Quote Originally Posted by Veccy_c_gsi View Post
    yeah most certainly,i`ll take in as much as i can tomoz eves
    S.Wales, Nr Swansea
    good man
    Regular Member Ashtoroth's Avatar
    Hiya.
    I am interested in doing this too, from what i have found out u need the right colour screen i have been told there is 5-6 diffrent ones (4:3 & 16:9 Aspects, may meen needing new vents). You also need a RGB (Red Green Blue grphics cable) between the CD70 and Display (VX part No. 13189491 (cost from dealers around £60)). Here is where i am not sure on and would like to know, the display needs to be blanked ?? to allow Tech2 To connect to car?? I beleve time on Tech2 is £60 a hour so the charge a pound a min at garages ??
    Anyone done this upgrade???
    Ashtoroth
    12 Post(s)
    Trim : elite
    Year : 2011
    this upgrade will be done this eves for a felow member so i`ll let you
    know how it goes.
    Regular Member Neil's Avatar
    Feb 2007
    The pool
    Would it be possible to upgrade to colour for the CD30?
    12 Post(s)
    Trim : elite
    Year : 2011
    hi ppl
    right i have just got back after trying the tech2 for the colour display but
    me m8 couldnt get it to programme as due to the colour display not getting
    divorced from the origional head unit that the colour display was with
    origionally but if this was de programmed from the origional head unit then it
    would of worked without a doubt so if anyone is thinking of this upgrade
    then make sure that the display unit has been divorced for the actual head
    unit,otherwise you will have the same problem but although if it had been
    then it would work and also the displays are interchangeable to and from
    other head units as long as its been programmed out from the origional head
    unit.
    we aint left it at that at the moment as we have an idea up our sleeves so
    let you know in due course.
    hope i ave explained it easy enough
    12 Post(s)
    Trim : elite
    Year : 2011
    hi all
    right latest update on fitting the colour display,
    the colour display is now fitted and working in replace of the mono
    display,we managed to get it divorced from its origional head unit and
    re-programmed into the car which it is now in and the club member that it
    was sorted for is a happy chappie so if anyone is thinking of replacing the
    mono display for the colour 1 then it can be done no problem BUT as long as
    the colour display is de-programmed from its origional head unit,thats the
    most important thing thats shud be done.
    job well done and complete in the end.
  1. Display screen upgrade
    By lewcdti in forum Electrical & ICE (including SatNav)
    Last Post: 15th October 2010, 13:29
  2. screen upgrade
    By khile in forum Electrical & ICE (including SatNav)
    Last Post: 18th March 2010, 00:28
  3. Screen Upgrade
    By wstwatson in forum Electrical & ICE (including SatNav)
    Last Post: 9th July 2008, 09:50
  4. Screen upgrade
    By Jim Bob in forum Vectra C / Signum Car Chat
    Last Post: 16th March 2007, 17:52
  5. Screen upgrade
    By Jim Bob in forum Electrical & ICE (including SatNav)
    Last Post: 13th March 2007, 12:35
