Thread: Will replacing the Accelerator fix this fault?
    Regular Member Tyler Durden's Avatar
    Oct 2018
    Shrewsbury
    Engine : 2.0T
    Default Will replacing the Accelerator fix this fault?
    I've noticed my car "holding onto revs" (this is the best way I can think to describe it). If I blip the throttle the revs rise quickly, but fall much slower. When driving it has the effect of lower than expected engine breaking.
    I have plugged in an OBD2 reader and looked at the throttle position sensor, and found that the throttle position goes from 18% open to 70% open within the first 1/3rd of pedal travel. The pedal doesn't make any difference after it is pressed more that 1/3rd.
    It seems likely that the pedal position system is broken in some way. I removed the pedal opened it up and see nothing obvious so I think I'll replace it.
    Any thoughts?
    Nov 2007
    DERBY
    24 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Do it,if you can get hold of one cheaply enough..ie at a local breakers.
    Oct 2018
    Shrewsbury
    Engine : 2.0T
    Got one on it's way from ebay, only a tenner.
    Hopefully it sorts it.
    Oct 2018
    Shrewsbury
    Engine : 2.0T
    New pedal fitted today and issue is unresolved. Any other options I could look into?
    Has anyone else got this issue, I'm starting to wonder if it is normal behaviour.
    Regular Member puppet's Avatar
    Feb 2010
    East Ayrshire
    10 Post(s)
    Vehicle : Insignia 1.8 SRi
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    Had something sort of similar on my Insignia, not sure if the Vecs work the same.
    Eventually turned out to be the settings of the aircon/recirc that were causing it. Presumably with certain settings, there is higher load on the engine, therefore the control system/black boxes were somehow "damping" the revs coming back down to avoid a stall situation.
    Might be worth having a tinker to see if it makes any difference.
    Oct 2018
    Shrewsbury
    Engine : 2.0T
    That seems a stretch as the car only has pretty basic climate control, but I'll check it out. Thanks
  1. Accelerator
    By Dannyclarke in forum Electrical & ICE (including SatNav)
    Last Post: 17th June 2017, 23:41
  2. Elecric accelerator
    By ARFA in forum Electrical & ICE (including SatNav)
    Last Post: 6th May 2014, 12:18
  3. ECU Light on, accelerator pedal fault? need wiring diagrams
    By Mr.Matt in forum Electrical & ICE (including SatNav)
    Last Post: 7th December 2012, 14:23
  4. accelerator goes 'flat'
    By Videoman in forum Engine & Drivetrain
    Last Post: 30th October 2009, 12:22
  5. no accelerator!!!
    By alexgrfc in forum Engine & Drivetrain
    Last Post: 5th November 2008, 22:38
