Likes Likes:  2
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Egr blanking exhaust manifold
  1. #11
    Aug 2019
    Sweden
    Vehicle : Saab
    Trim : 9-3
    Engine : Z19dth
    Year : 2008
    Quote Originally Posted by autov View Post
    So do you want to blank the exhaust manifold and still have the egr pipe bolted to the manifold so no exhaust gas's go through it to the egr valve ?.
    If so i would make a steel blanking plate of a minimum thickness of 3 mm but preferably 5-6mm and use exhaust sealant between the manifold and the blanking plate and just bolt the egr pipe with a new gasket to the blanking plate. Or you could fit the egr pipe without a gasket to the exhaust manifold blanking plate and fit a thin blanking plate at the inlet manifold to egr valve so that it seals for the incoming air from the turbo.
    Yes I want to blank egr at exhaust manifold and still have egr pipe bolted to manifold.
    My plate is 1.5mm stainless steel.
    I think it's thick enough to withstand the heat from exhaust manifold.
    I have exhaust sealant and can try to use that between manifold and plate.
    Why must it be minimum 3mm?
    I've got some construction steel but that is 12mm I think and it will be very hard to use that and still be able to get egr pipe on manifold.
    I also have blanked of egr on inlet manifold with 1.5mm stainless steel plate
  2. #12
    Sep 2014
    uk
    Engine : 1.9 cdti 150 x 3
    Year : 08/07
    Quote Originally Posted by FutureWorld View Post
    Why 3mm minimum ? just belt and braces and i think and it would be less likely to possibly warp and you don't want that as it's a bit awkward getting to to start remaking and resealing if it does warp/leak. 1.5mm seems thin BUT i suppose thinking about it how thick are exhaust pipes on motorcycles ect.
  3. #13
    Oct 2013
    Derby
    278 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    I gave the reason for a thick plate earlier in the thread, and don’t forget motorcycles are not diesels with very high exhaust gas temperatures are they? Also we are in the manifold area not the pipe work. You’ve got 2 cdti’s, look how big the casting is on them.
    Teapot Tuned 255/300
    Tech2 & MDI diagnostics
  4. #14
    Sep 2014
    uk
    Year : 08/07
    I've got 3 cdtis for my pains lol. I don't disagree with you thats why i thought at least 3mm and prefereably 5-6mm and thats were i'm going when i do mine . As i'm not sure what the temperature difference would be petrol to diesel at the manifold all i would say it would be VERY hot. Do tuners not make stainless manifolds for diesels like they do for petrol engines?
  5. #15
    Oct 2013
    Derby
    278 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Yes of course, but not a large casting with a little hole covered by a thin plate that would heat up more than the casting. It’s also why it’s recommended to remove or blank the egr system off there as the hot exhaust gases moreso from a tuned engine have been known to burst the water cooler.
  6. #16
    Nov 2019
    GB
    Vehicle : vectra c
    Trim : Sri
    Engine : 1.9cdti 150
    New gasket, blue gasket sealant and a thick blank or if using a thin blank a very thick support behind to ensure it doesn't warp. Like one did one day
    I had the same happen it just bends I used the collor off the egr pipe as a support and it worked very well
    Sent from my SM-A105FN using Tapatalk
  7. #17
    Apr 2016
    Ipswich
    42 Post(s)
    Vehicle : Vectra C
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Year : 2003
    Mileage : 140000
    if i was him i would just cut some out of that 1.2mm stainless steel he has, (use the bought one as a template) stack-em up and be done with it, he only needs a proper seal on the first one anyway.. than do the same on the other side of the pipe done.
  1. Blanking egr cooler / manifold
    By jamie1991 in forum Engine & Drivetrain
    Last Post: 20th February 2019, 00:05
  2. Replies: 6
    Last Post: 4th October 2018, 11:25
  3. Exhaust manifold access for egr blanking
    By cheese_za in forum Engine & Drivetrain
    Last Post: 8th February 2018, 23:11
  4. Peoples thoughts with inlet manifold blanking?
    By Tommyturbo217 in forum Diesel Engine related
    Last Post: 22nd November 2016, 18:16
  5. is it worth blanking with new inlet manifold (cdti 150)
    By monty2000 in forum Vectra C / Signum Car Chat
    Last Post: 6th July 2010, 20:35
