Thread: Been here a while.
    Aug 2015
    up north
    Vehicle : C vectra
    Trim : elite
    Engine : d
    Year : 08
    Default Been here a while.
    Thought I better introduce myself having registered years ago and never getting round to it. Bought an 08 CDTI Elite with 100k on the clock as a cheap run around 3 years ago after my VWT4 blew a gearbox.
    Love the car had no major problems bar replacing front wheel bearings and a rear brake line since owning it, as well as the usual consumables. Have put 55k on the clock since purchase which isn't bad, seeing as its only used really in the winter months when the weather is too bad for the bike and the deer are out.
    Only real winge about it is the alarm goes off on its own sometimes (Just use drivers door manually to circumvent) and having replaced wiper linkages there is a lot more "slack" in the wiper motion. Apart form those she is a great wee car.
    Regular Member Big_G's Avatar
    Apr 2009
    5 Post(s)
    Hi fink. Sounds like you've had some good trouble free motoring.
    The alarm sounding is a simple fix - replace the sounder unit as the internal battery is faulty. The sounder is located in the inner wing (passenger side I think). Just remove the inner wheel arch and you'll see it.
    Wiper linkages is a very common problem but sounds like you've fixed it.
    Aug 2015
    up north
    Vehicle : C vectra
    Trim : elite
    Engine : d
    Year : 08
    Thanks for tip on sounder. Will give it a look when I can get round to it. Cheers
    Apr 2009
    5 Post(s)
    Ah hang on, the sounder is in the boot behind the panel on the Vectra's, I'm thinking of my old Astra.
