Results 1 to 4 of 4
Thread: I Dont know, Maybe injectors??? need help 1.9 cdti shaking in 1200
    Oct 2019
    Amiens
    Vehicle : Opel vectra C caravan
    Trim : Vectra C Caravan
    Engine : 1.9 cdti
    confused I Dont know, Maybe injectors??? need help 1.9 cdti shaking in 1200
    Hello, I want to ask you about my 1.9 cdti 120hp. My main problem is when you hold it at about 1200 in idle, you can feel shaking in the car, as well as the smell of burnt fuel comes out of the hood and enters in the saloon. the car began to use more fuel than before. I changed all filters except diesel filter. cleared all the sensors,I feel that the motor is not working as well as before. he started some kind of jerking and little loss of power at low rpm. No warning lights, no problem found with diagnostic tool.
    HEED HELP thank you.
    Apr 2016
    Ipswich
    93 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Year : 2003
    Mileage : 140000
    you suspect it is injector related but you haven't changed the fuel filter? it is the first thing you'd change in this case... the next thing would be to pull the injectors and replace the copper seals on all of them...
    Oct 2019
    Amiens
    Engine : 1.9 cdti
    Ok I will change it thank you
    Regular Member Jim Carey's Avatar
    Jul 2019
    Portsmouth
    Vehicle : vectra
    Trim : Sri xp
    Engine : 1.8 vvt
    Mileage : 77850
    Did u find the cause of the problem, exactly what I have but on a 1.8vvt, engine judder at low rpm at idle and stinks of fuel.. Already replaced 1 injector.
  1. 1.9 cdti - Engine shaking, rattle while turning it off - Z19DT
    By kaliope in forum Vectra C / Signum Car Chat
    Last Post: 14th June 2017, 15:10
  2. CDTI 150 vibration in 1st gear, shaking whole car (Astra)
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 27th March 2015, 20:18
  3. vectra 1.9 cdti 120 bhp 8v engine vibrating rattling shaking
    By IRvectra786 in forum Engine & Drivetrain
    Last Post: 2nd May 2013, 12:05
  4. Replies: 8
    Last Post: 14th March 2011, 20:21
  5. Injectors x4 1.9 cdti 150
    By mark230678 in forum Parts for sale
    Last Post: 30th June 2009, 22:05
