Results 1 to 4 of 4
Thread: recommend clutch brands plz
    Mar 2017
    newcastle
    Vehicle : vectra
    Trim : life
    Engine : 1.8 16v
    Default recommend clutch brands plz
    hi guys im after some recommend clutch brands
    1 luk 2 sachs but whats 3,4.5 etc plz
    clutch is for my vectra c 1.8 16v 05 plate life model.
    many thanks
    Apr 2016
    Ipswich
    52 Post(s)
    Vehicle : Vectra C
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Year : 2003
    Mileage : 140000
    F17 gearbox right? basically all you need to worry about is giving ecp the right reg. number... they can check it better in store (they can match it with your cars vin)
    FYI if you get either Luk or Sachs you''ll be fine both brands are good, but apparently Sachs has been designed that if it fails it won't break the bellhousing of the gearbox or the flywheel.. I recently had a failed clutch plate and the damage it can do goes from breaking the bellhousing to actually seizing the crankshaft... so stay away from cheap manufactured clutches... look in my car diary for a picture of a clutchplate failure. Note that both the flywheel and the pressure plate were fine, it was just the inferior metal that couldn't handle the torque because the friction material could easily last a few more years... that all said..
    either Luk or Sachs will do just fine
    Regular Member sigrid3.0cdti's Avatar
    Dec 2018
    thanet
    Vehicle : signum elite vectra sri cdti
    Trim : elite sri
    Engine : 3.0cdti sri200+astra
    Luk all the way
    Mar 2017
    newcastle
    Vehicle : vectra
    Trim : life
    Engine : 1.8 16v
    after much research etc i got a sachs 3 piece. unfortunately the clutch is fine it was the gearbox that died. all out now so waiting to get a used f17 box.
  1. Filter brands
    By woodspsx1 in forum Engine & Drivetrain
    Last Post: 7th April 2015, 21:33
  2. Coilover Brands
    By H20JOE in forum Styling
    Last Post: 26th January 2014, 20:18
  3. Y32SE Water Pump - any non oem brands to avoid or recommend?
    By r1chv in forum Vectra C / Signum Car Chat
    Last Post: 15th April 2013, 20:34
  4. BTCC Brands
    By chewy71 in forum Motorsport / Formula 1 etc. chat
    Last Post: 11th October 2011, 09:39
  5. Wtcc! Brands
    By mitch in forum Motorsport / Formula 1 etc. chat
    Last Post: 14th July 2010, 18:36
