Tbh iv tried loads of different led and updated builds as I drive at night up in the highlands, those are the best iv had
Sent from my iPhone using Tapatalk
Right here you have a the cheapest listings on amazon:
H7 led bulbs with a reflector (main or high beam)
H3 led bulbs with a reflector (preface foglight)
H1 led bulbs with a reflector (facelift foglight)
T10 led bulbs ....are all the same though so you can use whatever but with out the modification as known on this site they will flicker. although you won't get the bulb out error on the screen and actually i have the same ones in my headlights and reading light.
All interesting stuff, not seen any of this until now.
Teapot Tuned 255/300
Tech2 & MDI diagnostics + SPS
lol i did my research on a page that most of you lot completely disregard... Aliexpress... Why you wonder? well it is easy if something gets invented it usually gets fabricated in China, the chinese have this thing where they'll copy the lot and sell it under different brands... but with one difference they actually put up videos so you can see the light output from those bulbs in standard reflector housings... that said... I found out last night that Novsight has upgraded led bulbs they call S2 Plus.. they have bigger shields and the light cutoff is just as sharp as normal halogen bulbs in reflector housings... but the light output is available from 4300K up to 8000K so from normal halogen (yellowish white) colour to bright white (blueish white)
I myself would now just go for 6000k as it is pure white light, although i know that can cause reflection on rain and snow when driving through that at night on an unlit road... if you don't want that, choose between 4300k and 5000k the yellowish tint actually doesn't reflect back at you but the whiter the light output the more it reflects... anyway i'm digressing,
if you are ordering Novsight led bulbs go for the S2 plus versions, but they are more expensive
Here is a link to the Novsight store on Aliexpress
It might take a bit longer if you order through aliexpress but you could save about 20 pounds a set because you are buying direct from the manfacturer
