Likes Likes:  7
Results 1 to 10 of 30
Thread: Hids/led bulbs for preface
    VIP-Member Samyam's Avatar
    Jan 2018
    Coventry
    8 Post(s)
    Vehicle : Vauxhall astra
    Trim : Sxi
    Engine : 1.6
    Default Hids/led bulbs for preface
    Iím changing all the bulbs on my insignia to led
    I know the front headlights arenít projector. I never understand why they didnít fit projectors as standard like they did on the vectra facelift or pre.
    Could I run led bulbs with out blinding other drivers or would I need h7r hids
    What are people running on there prefaclifts
    Sent from my iPhone using Tapatalk
    Regular Member Daywalker's Avatar
    Aug 2007
    Virbaliskiu km, Kaunas raj
    Vehicle : Astra Sports Tourer
    Trim : active
    Engine : 1.7cdti
    If you havent got projector h/lamps then you could try some brighter bulbs ie osram nightbreakers which made a difference on my Astra (without projector h/lamps)
    Full Member petrolcan's Avatar
    Dec 2015
    Watford
    20 Post(s)
    Trim : Elegance
    Engine : 1.9 CDTI (120)
    If you fit ultra bright bulbs in standard reflector headlamps you will blind every oncoming car and they will think you a ****
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    45 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    Quote Originally Posted by petrolcan View Post
    if the bulb is made for a reflector housing it won't cause blinding unless the headlight isn't set properly and pointing up thus blinding people, yes they might notice your headlight output is bright but hey that doesn't mean they are blinding...
  5. Likes Daywalker liked this post
  6. #5
    12 Post(s)
    Quote Originally Posted by Samyam View Post
    I know the front headlights aren’t projector. I never understand why they didn’t fit projectors as standard like they did on the vectra facelift or pre.
    1. Cost saving.
    2. The light output through projectors with standard bulbs was crap.
  7. #6
    Dec 2015
    Watford
    20 Post(s)
    Trim : Elegance
    Quote Originally Posted by northpole View Post
    Aftermarket HIDs and LED headlight bulbs literally throw light out in all directions. Put them in a reflector housing and it is blinding to oncoming cars. It's the reason I won't put them in the OH's car yet happily have them in mine.
  8. #7
    Apr 2016
    Ipswich
    45 Post(s)
    Mileage : 140000
    Yes the cheap ones chuck it everywhere the ones made for reflector housings don't and are more expensive... cheap made leds do the same expensive leds don't (although most of them are made for reflector housings) so they should be just fine.
  9. #8
    Dec 2015
    Watford
    20 Post(s)
    Trim : Elegance
    https://www.powerbulbs.com/product/o...dlight-h7-twin
    Not cheap but these will fit in the OH's IX20 and they are pretty much the same design as the ebay specials you get for under £20. I've taken one of my LEDs and put it into the Hyundai and whilst it was indeed brighter it was a machine gun scatter approach to light output in comparison to my projector headlight.
    I'd love for you to point me to a HID or LED headlight set specifically made for reflector headlamps because my research hasn't come up with a single one and I've had a lot of time on my hands recently.
  10. #9
    Apr 2016
    Ipswich
    45 Post(s)
    Mileage : 140000
    Look for evitek f2 (bulb type) ... they are shielded led bulbs and sold by different brands... it is just one of them... there are more brands but I don't know them all
    Also did you make sure you had the bulb in the right way around? Sometimes they are directional and fitting them upside down causes glare.
  11. #10
    Sep 2018
    Glasgow
    NOVSIGHT H4 LED Headlight Bulbs... https://www.amazon.co.uk/dp/B076ZJBS...p_mob_ap_share
    Thatís the bulbs I put in the works van, line up perfect and donít break the bank ( I know itís H4 but concepts the same)
  1. daft question regarding hids preface to facelift..
    By taffy bhoy in forum Electrical & ICE (including SatNav)
    Last Post: 21st September 2014, 22:19
  2. For Sale: HIDS : Ballasts, Bulbs and Cancellers
    By Envy in forum Parts for sale
    Last Post: 11th March 2013, 20:44
  3. fitting hids to a preface, where have you mounted ballasts?
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2013, 01:02
  4. What bulbs do you use? (No HIDS)
    By lew1984 in forum Vectra C / Signum Car Chat
    Last Post: 9th January 2012, 08:49
  5. hids preface to facelift
    By hairy31 in forum Electrical & ICE (including SatNav)
    Last Post: 5th August 2011, 01:28
