Thanks Thanks:  1
Likes Likes:  2
Results 1 to 10 of 15
Thread: clutch n that
    Mar 2017
    newcastle
    Vehicle : vectra
    Trim : life
    Engine : 1.8 16v
    Default clutch n that
    hi guys n gals. my `car knackered last week, the clutch went and only been in use just over a year. so question is should i fix it. i love me vectra and know it needs very little. now with the clutch, i know LUK. is best and have found one at £148 for my motor. what other clutch brands are good. apart from the clutch and fliud, what else is needed. ie gaskets sealant and any other components? cheers folks
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    45 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    You'll want :
    - clutch
    - bearing
    - dmf
    - csc
    - brake fluid
    Those are the needed parts
    You might want to consider replacing the gearbox oil also...
    Full Member petrolcan's Avatar
    Dec 2015
    Watford
    20 Post(s)
    Trim : Elegance
    Engine : 1.9 CDTI (120)
    The 1.8 petrol has a DMF?
    Regular Member JagRigger's Avatar
    Norfolk
    Engine : 1.8 VVT
    Mileage : ... 235K!
    Nope
  5. Thanks petrolcan thanked for this post
  6. #5
    Apr 2016
    Ipswich
    45 Post(s)
    Mileage : 140000
    Well that is my mistake I mistakenly thought all vectra c's were delivered with the dmf
    Forgot the 1.8 actually has the f17 gearbox...
  7. #6
    Mar 2017
    newcastle
    Vehicle : vectra
    Trim : life
    Engine : 1.8 16v
    so apart from dmf alls good? will the driveshaft seals need replacing? is it best to just use the old bolts or replace them? was also thinking should i replace both drive shafts as its coming apart anyways. at same time im fitting a new track rod end kit. and if im able depending if i remove engine from the car, i have a full timing belt kit to go on. both belts, tensioner, water pump. just wondering should i replace any other bits like aux belt tensioner/pulleys
  8. #7
    Apr 2016
    Ipswich
    45 Post(s)
    Mileage : 140000
    If you are going to do everything you might aswel hire an engine hoist loosen the 4 engine mounts and lift the whole lot out, that way you can get around and do it all in one go... because it gives you access to everything .. that said aux belt and tensioner will be a goodthing to do also... all in all it won't be cheap to you do it all... and back to your driveshafts.. no if they are fine keep 'em... only spend money where it is needed.
    Service parts, oil, filters, plugs etc will add to the bill also so look at it and how long it will take to do it all... you'll have a big paperweight in the time you are doing all of that.
  9. #8
    Mar 2017
    newcastle
    Vehicle : vectra
    Trim : life
    Engine : 1.8 16v
    thanks. i already have the bits apart from gearbox oil and aux belt tensioner. havent bought driveshafts.. with the track rod ends seperate from the kit as mistakenly i have 4.. 2 with kit and 2 seperately. all brand new. the ones seperately move, the ends. but the ones in the kit are rigid. which ones are best to use.. ive checked into engine hoist £46 to hire for a week. not sure if u get delivery or pickup included. when removing engine does bonnet need removed and also do the straps come with the hoist or buy my own. many thanks. oh totally forgot while out i may aswell clean it and clean inlet manifold
  10. #9
    Apr 2016
    Ipswich
    45 Post(s)
    Mileage : 140000
    If you hire an engine hoist it should come with either chains with hooks or straps... just ask if they come with it.
    Use the new ones they shouldn't move like that.
    Yes you'll need to remove the bonnet... sounds like extra work but it is less work than dropping the subframe and than trying to get the gearbox out... (it only comes out one way and you'll have to put it back in the same way but in reverse)
    Also by using the engine hoist you have more than enough space to do the cam belt and auxiliary bits...
    But you'll loose your aircon gas and the coolant. You'll also will need to detach any looms, pipes and hoses that connect to the engine... just so you know
    Yes it is more work but you are doing it all in one go so you are better off using an engine hoist.
  11. #10
    Mar 2017
    newcastle
    Vehicle : vectra
    Trim : life
    Engine : 1.8 16v
    thanks, thats what i was thinking. they are brand new the track rod ends. im wondering if u buy items seperate do they move, instead of being in a kit.(which will be rigid) but anyhow i will use the kit which has 2 track rod ends, 2 inner rods, and the 2 rubber covers. as long as nothing goes wrong im hoping a week will be enough time. i have coolant. as wiith the aircon, its a good time to replace the grill as its a bit damaged. i have already put a new radiator on. i will get on to europarts about those 2 track rod ends.when u mentioned bearings, are those for the driveshafts at engine end? any seals needed replacing clutch. sorry all these questions but i just want to make sure i have everything needed.
  1. Replies: 0
    Last Post: 23rd December 2013, 14:16
  2. Replies: 4
    Last Post: 22nd April 2013, 20:59
  3. Clutch slipping and loosing clutch/brake fluid
    By marty_b0y in forum Engine & Drivetrain
    Last Post: 31st May 2012, 00:18
