So I’m trying to find out the outer diameter size of the turbo inlet on a Vectra 1.9 CDTi 150bhp with little luck. Some one of you lot is bound to know this?
thanks in advance
thanks in advance
Anyone?
use a vernier caliper... it'll tell you the diameter right there and than... and because it is a precision measurement tool it'll be spot on.
I’m trying to find out without having to strip my own car. I’m aiming to buy an induction kit designed for an Astra 150bhp. I’ve discovered that the inlet pipe for the Astra is smaller at the AFM end, but need to know the turbo end. Ideally I’d like to just strip the car when I am fitting said induction kit, because stripping the car twice isn’t a great idea, it means twice the expenditure in terms of coolant etc..
