Likes Likes:  2
Results 1 to 10 of 30
Thread: Lower charge hose popping off (Saab 9-5 1.9 Tid)
    Regular Member mikseymono's Avatar
    Mar 2014
    Bretagne, France
    Vehicle : Saab 9-5 1.9
    Trim : Basic
    Engine : 1.9 Tid
    Mileage : 80,000
    Default Lower charge hose popping off (Saab 9-5 1.9 Tid)
    Hi team...
    So in the last year the 3 inch in diameter hose that connects to the radiator, bottom right hand side as you look at it from the front pops off. Part number 12762043
    The hose is one of those silicone ones and connects to the hard plastic male bit of the lower rad. I have two clamps holding it on...but it seems to blow off every 6 months or so. There is some oil residue in there...maybe about 1/2 teaspoon....
    Question is: I have never changed the hose..140k covered so far...is it time for a new one? Or is it something else?
    Thank you in advance,
    M
    Midlands - Vxr Owning Dick Dog_Book's Avatar
    Oct 2013
    Derby
    295 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    If you’ve got oil in the water could be another fault maybe head gasket?
    Teapot Tuned 255/300
    Tech2 & MDI diagnostics + SPS
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    24 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Where was the mention of water?..you using your psychic powers again Steve?..
    Personally id change it,for how much its gonna cost. Probs the clamps as well.After a thorough clean of the surfaces.
  4. Likes matthewp1633 liked this post
  5. #4
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    45 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    Are you on about the radiator or the intercooler? If it is the intercooler, get a new v- band clamp and replace the 2 with that one that should do the trick.
  6. #5
    Nov 2007
    DERBY
    24 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    My apologies..radiator init...******...
    Quote Originally Posted by nikroc View Post
  7. #6
    Mar 2014
    Bretagne, France
    Trim : Basic
    Engine : 1.9 Tid
    Mileage : 80,000
    well have just cleaned all connections.......hardly any oil...just a slight misting...so think it must be the weedy connections.......will get some proper v clamps and maybe put some mastic sealer on before clamping up...
    M
  8. #7
    Sep 2018
    Herts
    15 Post(s)
    Trim : Best
    Engine : 2.0T
    OEM hoses wouldn't be silicon, they would be rubber. If it is genuinely silicon then it's an aftermarket item. Silicon hoses are notorious for popping off, you could try filing the metal collar it connects to, in order to roughen the surface and increase friction.
  9. #8
    Mar 2014
    Bretagne, France
    Trim : Basic
    Engine : 1.9 Tid
    Mileage : 80,000
    just had a look..and it's rubber....so OEM...maybe a smear of mastic sealer will help as well....Its the plastic male part on the intercooler that is smooth.....not metal on mine....which probably doesn't help matters...maybe I should roughen it up a bit...
  10. #9
    Oct 2013
    Derby
    295 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    V clamps aren’t used on the intercoolers, might be some pics of some of the ones I replaced on mine in the diary at work so cant post them
  11. #10
    Mar 2014
    Bretagne, France
    Trim : Basic
    Engine : 1.9 Tid
    Mileage : 80,000
    Hi team...well after another long 2 hr journey it did the same again.......
    I made reparations, put pipe back on with Jubilee clip, only one this time and not the three I had on before and managed to drive home.. Kept it at 2100 rpm max and all was well.
    When I got home I then took it up and down my lane and gave it a good spanking to 4500 rpm and the pipe did not come off!
    So...a bit of a loss really.
    Options:
    1 - new pipe...OEM one is 15 years old
    2 -New clamps
    3 - Would there be a pressure issue? At 2000 rpm it was fine.
    4 - Anything else?!
    Thank you in advance....
    M
  1. Silicone Hose kit and vacum hose, Worth buying?
    By rfc52 in forum Vectra C / Signum Car Chat
    Last Post: 29th June 2014, 18:42
  2. For Sale: 50ft expandable hose green like the x hose
    By CraigoT in forum General items for sale
    Last Post: 17th August 2013, 23:17
  3. Expansion tank lower hose clip removal help please
    By Ace-VXR in forum Engine & Drivetrain
    Last Post: 6th May 2012, 16:44
  4. saab 93 samco boost hose fitment (z20net)
    By chesh1980 in forum Styling
    Last Post: 14th March 2012, 18:09
