Thread: Limp mode - fed up with it!
    Regular Member ChrisFox's Avatar
    Feb 2007
    Northampton
    Default Limp mode - fed up with it!
    My 2.2DTI still keeps going into limp mode at low revs under pressure and I am getting fed up with it!
    It has been into the stealers twice, all they have told me both times is that they can see it went into limp mode but not why...useless as ever!
    I have checked all the hoses myself for splits and can't find anything!
    Does anyone have any ideas or experiences of how to fix this?
    Regular Member Vec-trance's Avatar
    Feb 2007
    Kent
    Have you tried putting viagra in the tank?
    Nr Cardiff
    That's helpful
    Feb 2007
    Northampton
    LOL...great answer, doesn't help, but great answer!!!
    If the dealer can see it went into Limp Mode then surely it's registered a fault code.
    The next time it does it call out your breakdown recovery service and ask them to plug in there fault code reader and see what they say.
    morton
    i agree with AJ ! if its in limp mode there must be a code ! the wifes 2.2 dti is a B , but its the same engine i think !? with hers is was the cam sensor ! it would come on intermitent ! the warranty covered it which is a good job as it was cured properly first time round and second time it needed a vacuum pump as well !
    Feb 2006
    Guttedsville
    Hi Chris, I think I've said before elsewhere, this is where mine started playing up. Initially it was the boost sensor which needed a good clean up and refit. This solved the problem for a while, but then we went down the dark alley of replacement turbo's, hoses, sensors,vaccum switches and pipes all before they could really say what had happened.
    Quite common for it to go into limp mode due to a problem with the Exhaust Gas Recirculation valve.
    Also, poor starting and cutting out after starting caused by airleaks through fuel injector seals.
  1. Limp mode help
    By neill in forum Engine & Drivetrain
    Last Post: 20th March 2012, 19:53
  2. Limp mode or dead mode
    By JSYSH466Y in forum Engine & Drivetrain
    Last Post: 2nd July 2009, 09:46
  3. Limp mode
    By dan1983 in forum Vectra C / Signum Car Chat
    Last Post: 3rd July 2008, 18:35
  4. Limp mode
    Last Post: 3rd July 2008, 10:34
  5. limp mode
    By vauxvec in forum Vectra C / Signum Car Chat
    Last Post: 15th June 2008, 22:03
