Results 1 to 2 of 2
Thread: 2008 1.9CdTi 120 - Fuel Pressure Issues
    Jul 2018
    Middlesbrough
    Trim : Exclusiv
    Engine : 1.9CDTi
    Default 2008 1.9CdTi 120 - Fuel Pressure Issues
    Not too sure if this fits under Tuning or Troubleshooting, primarily itís troubleshooting and I canít seem to find any answers relating to my engine on here from a search.
    Car is a 2008 Vectra 1.9 Z19DT.
    Ive recently had a Teapot map put onto it which has highlighted an issue with my fuel pressure.
    The issue is that at WOT in any gear above 2nd the car jumps into limp mode and throws the EML up just as you hit 3000rpm. Worth noting that it feels really strong right up to the point where EML/limp kicks in, and at anything other than WOT it doesnít do it.
    Iíve done a fair few Op-Com logs which seem pretty consistent in highlighting that the fuel rail pressure canít seem to reach anything above 125Mpa. The demand runs up to 160Mpa which results in the EML flagging a P0001-75 fault code.
    The car drives really well in every other scenario, Iíve got no other engine issues and no other fault codes present.
    So I've done the following so far:
    New OEM Fuel Filter
    2x Vpower tanks
    1x Cataclean bottle in each tank
    Planning on pulling the LPFP from the tank at the weekend and making sure thereís no blockages there.
    My questions are:
    1. A few people have mentioned the fuel pumps are prone to failing. Can I fit an R80 pump to this engine? And if so can it be fit with the larger 8v belt pulley.
    2. Iím assuming that the fuel rail sensor it self is a possibility too, is there any difference between the 16v and the 8v units? Or is there any better options I can go for rather than a straight swap to a standard unit?
    3. Injectors - are these prone to internal leakage as in back into the return lines?
    4. Any other pointers for common issues that could be causing this?
    Jul 2018
    Middlesbrough
    Trim : Exclusiv
    Engine : 1.9CDTi
    One of the fuel logs attached. This is 3rd gear starting at 25mph at WOT.
  1. Vectra c 1.9cdti facelift 120bhp intermittent low fuel pressure
    By danbax in forum Vectra C / Signum Troubleshooting
    Last Post: 5th January 2018, 19:30
  2. Vectra C 1.,9CDTi 150 SRi - fuel pressure 'sensor' or 'regulator'?
    By jonboyp1976 in forum Engine & Drivetrain
    Last Post: 20th February 2016, 23:23
  3. 2.2 direct fuel pump and fuel pressure regulator
    By w111y in forum Engine & Drivetrain
    Last Post: 11th July 2012, 22:12
  4. Replacing Vectra SRI 1.9CDTI 150 2008 Fuel Filter?
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 19th April 2012, 21:52
  5. Fuel pressure sensor/fuel pump failure list following Watchdog investigation.
    By happychappy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 13:18
