Thanks Thanks:  1
Thread: 2008 vectra C 1.9cdti 120bhp Gearbox problem
    Feb 2016
    Dublin, Ireland
    Trim : CDTI
    Engine : 1.9 CDTI
    Default 2008 vectra C 1.9cdti 120bhp Gearbox problem
    Hi
    I was driving earlier this evening for an hour or so and all of a sudden, I got a whirring / squealing noise when I shifted up to 5th. I get it less in 6th and a little bit in 2nd. I drove most of the rest of the journey in 3rd/4th as they seem to be okay.
    I'm guessing the gearbox is toast, right? If so, I've a few questions:
    I have a 3h return journey home to make tomorrow, am I doing more damage to the gearbox by driving this? Or once it's damaged, is it just damaged and driving more won't make much difference? Obviously, it could give up completely en route but that's a different problem.
    Secondly, what's my best option for fixing this? Recondition the existing one? Get one from a breaking yard? Or something else?
    Thanks in advance
    Regular Member Daywalker's Avatar
    Aug 2007
    Virbaliskiu km, Kaunas raj
    Vehicle : Astra Sports Tourer
    Trim : active
    Engine : 1.7cdti
    Not sure what gearbox you have but if it is the M32 box then the noise could be your bearings are gone. This link might be of help to you http://www.wgmotorworks.co.uk/repair...n/m32-gearbox/
  3. Thanks macdanger thanked for this post
  4. #3
    Feb 2016
    Dublin, Ireland
    Trim : CDTI
    Engine : 1.9 CDTI
    Quote Originally Posted by Daywalker View Post
    Sound, thanks for that. It sounds fairly similar to what's described in that link.
    One last question, would I be as well getting the clutch done at the same time? Or is that not necessary?
  5. #4
    Regular Member fatfred's Avatar
    Dec 2013
    Bristol
    15 Post(s)
    Vehicle : Insignia
    Engine : 1.6D
    Year : 2018
    Mileage : 1 hundred
    Quote Originally Posted by macdanger View Post
    If your paying the labour to remove the box, you'd be daft to not replace the full clutch assembly inc. dmf in my eyes.
  6. #5
    Aug 2007
    Trim : active
    Engine : 1.7cdti
    while gearbox is off you might as well bite the bullet and have the DMF and clutch changed at the same time
  7. #6
    Full Member
    Jul 2018
    Middlesbrough
    Trim : Exclusiv
    Engine : 1.9CDTi
    I had the same issue, carried on driving for around 40 miles and I lost most gears car was un-driveable.
    Changed the box for another M32 which also started whining about 10,000 miles later. I also carried on driving that one and it covered another 1500 miles before I took it off. It’s luck of the draw as to how long they last after initial whining starts.
    i gave up at that point and did the F40 gearbox conversion
  8. #7
    Sep 2018
    Herts
    15 Post(s)
    Trim : Best
    Engine : 2.0T
    Slightly off topic, but I had a Rover 620 Turbo back in the '90's and the gearbox started whining at about 65k, which was a common fault with that model due to the turbo's torque. The car became undriveable at 120k...
  1. Vectra 1.9cdti 120bhp non start
    By danbax in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd January 2018, 13:35
  2. Vectra C 1.9cdti 120bhp egr Valve 2006
    By killalot in forum Vectra C / Signum Car Chat
    Last Post: 16th May 2017, 16:19
  3. Vectra 1.9cdti 120bhp cambelt
    By Nemises in forum Engine & Drivetrain
    Last Post: 17th July 2015, 13:39
  4. Vectra 120bhp gearbox
    Last Post: 20th May 2015, 18:03
  5. vectra 120bhp 1.9cdti misfire
    By daws in forum Engine & Drivetrain
    Last Post: 31st July 2013, 21:15
