Thanks Thanks:  2
Likes Likes:  3
Thread: Shock Absorber Identification Confusion
    VIP-Member Steel's Avatar
    Sheffield
    Trim : SRI CDTI NAV
    Mileage : 222,000
    Default Shock Absorber Identification Confusion
    I have often seen shock absorbers or suspension kits advertised secondhand for the Vectra, but I have been looking at a new setup, possibly something along the lines of a Bilstein B12 pro kit, but there appears to be a couple of different sets depending on chassis number, changing around September 2004.
    Not that this is a problem as I have my chassis number, but is there actually a difference? If buying secondhand how would you know?
    I have read elsewhere that the chassis was revised for facelift models which improved them, is this part of the revision? Spring/Damper rates etc and if it is that would mean mine is that bit of an oddball that I think it is having a chassis number that puts it on the later setup. Confused and interested at the same time.
    Any info greatly appreciated, I'm sure there is one or more of our number that will have the answers.
    Despite the cost of living it still seems popular!
    Midlands - Head case Organiser Dog_Book's Avatar
    Oct 2013
    Derby
    266 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Just go on the axle weights
    Teapot Tuned 245/300
    Tech2 & MDI diagnostics
  3. Likes Steel liked this post
  4. #3
    North West - RO bonehead's Avatar
    Feb 2015
    Warrington-ish
    102 Post(s)
    2 Thread(s)
    Trim : VXR!
    Engine : Z19DTH+
    Year : 57
    there is a difference in the front shock.
    something to do with the brake line mounting, or ABS cable mounting, along those lines.
    stick with new, anyone who has paid for a new B12 kit has thrashed the living daylights out of it!
    because........SIGNUM!
  5. Thanks Steel thanked for this post
  6. #4
    Sep 2018
    Herts
    15 Post(s)
    Trim : Best
    Engine : 2.0T
    Any minor changes to spring or damper rates would only apply to OEM parts - aftermarket manufacturers such as Bilstein use different states of tune anyway, so the changeover date would be irrelevant.
  7. Thanks Steel thanked for this post
  8. #5
    Sheffield
    Trim : SRI CDTI NAV
    Mileage : 222,000
    Default My question answered
    Quote Originally Posted by bonehead View Post
    Absolutely bang on @bonehead Decided to investigate today and the early pre chassis number 48999999 (left) has a different mounting for the ABS wiring from the later post chassis number 51000001 (right). I think the earlier one has a separate mounting bracket that bolts on to the bottom of the bracket.
  1. Help front shock absorber
    By yipikiaye in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2015, 21:59
  2. 2.0t shock absorber help
    By stefan7153 in forum Engine & Drivetrain
    Last Post: 8th March 2011, 21:17
  3. Shock Absorber Help
    By Skinner in forum Suspension, Wheels & Brakes
    Last Post: 10th April 2010, 23:23
  4. shock absorber
    By Dwabo in forum Handling & Braking
    Last Post: 30th September 2007, 12:07
