Thanks Thanks:  1
Results 1 to 10 of 14
Thread: Any hands make light work?
    Aug 2019
    Cannock
    Vehicle : Vectra 1.8 Exclusiv
    Trim : Red
    Engine : 1.8
    confused Any hands make light work?
    Help please. All lights work as required, when required, however the brake light on each side have decided to stay on but not the high level light. The bulb failure light is lit but there are no lights blown.
    To leave the car for any length of time I have to disconnect BOTH rear light clusters.
    I found one bulb on the left cluster to have an exceptionally high resistance. I changed that bulb and all bulbs now read between 1.1 ohms and 1.7 ohms. The brake lights are still lit.
    All I had done was to put the awning and poles for the caravan in the boot, on returning with a few more things I saw the lights had lit for no apparent reason.
    Sep 2018
    Herts
    15 Post(s)
    Trim : Best
    Engine : 2.0T
    Change the bulbs for good quality new ones. The bulb failure warning will show when a bulb is playing up but hasn't yet failed. Also when a brake light bulb does fail, a tail light bulb will work as a brake light instead, making the failure hard to spot.
    Aug 2019
    Cannock
    Trim : Red
    Engine : 1.8
    Thanks for the heads up "LastOne". I was going to change a couple of bulbs as they look "well worn" but I'll do as you suggest and change the lot.
    12 Post(s)
    Have you checked the brake pedal switch?
    Nottingham
    I also had an issue with corrosion on the bulb holder causing a bulb failure notification
    Aug 2019
    Cannock
    Trim : Red
    Engine : 1.8
    Yes, I have thanks.
    When the brake pedal is pressed the high level stop light comes on, instead of just the 2 lights.
    Oddly, when I connect my caravan this fault remains on the car but does not show on the caravan.
    Aug 2019
    Cannock
    Trim : Red
    Engine : 1.8
    Hi Stripey. Corrosion, bad contact or dirt I checked for along the way. I even checked nothing in the side boxes was causing a short.
    The only thing I have not tried is to change all the bulbs. I'll do that when the torrential rain stops.
    12 Post(s)
    Quote Originally Posted by Mattke3 View Post
    Yes, I have thanks.
    I might be wrong, but I'm sure I've read on here in the past that the brake switch is a two pole switch. One for the light clusters, and the other for the LED high level light.
    Aug 2019
    Cannock
    Trim : Red
    Engine : 1.8
    Big Dave, thanks. What you say is quite feasible, something I hadn't even thought about.
    Regular Member Teapot's Avatar
    woodbridge, suffolk
    262 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    Could be an issue with the REC. Try disconnecting the battery for 10 mins then reconnecting. If the propblem persists, then a replacement REC (Rear Electrical Centre) may be required.
  11. Thanks Mattke3 thanked for this post
  1. UHP Software Upgrade to make iPhone work
    By veccyman in forum Electrical & ICE (including SatNav)
    Last Post: 17th June 2013, 20:40
  2. Whats this and how do I make it work?
    By Signum-Steve in forum Electrical & ICE (including SatNav)
    Last Post: 18th November 2012, 18:59
  3. Make sport switch work
    Last Post: 25th July 2012, 21:07
  4. Whats needed to make heated seats work?
    By John LE in forum Electrical & ICE (including SatNav)
    Last Post: 3rd October 2010, 00:07
  5. Can you make it to work today....
    By bobby-tupper in forum The 'Off Topic' room
    Last Post: 3rd February 2009, 21:07
