Thread: Dab radio
    Regular Member Anth1718's Avatar
    Jan 2016
    Newcastle
    Vehicle : Vectra c
    Trim : Sri
    Engine : 1.8
    Year : 55
    Default Dab radio
    Looking for somebody that knows about dab radios and connection types.
    ive got a dab radio for my caravan and my new tv aerial also gets radio and dab.
    i had to by a splitter to split the signal from the normal radio and dab signals.
    but Iím getting no dab stations but I can get them in my car parked next to my caravan.
    is there different types of splitter could I have bought the wrong one ? I paid £4 for this splitter from eBay itís thin wire could it just be cheap rubbish?
    Regular Member Sindy's Avatar
    Dec 2015
    Yorks
    Trim : Mohican
    Engine : Z20NET
    Have you tried connecting direct to the aerial and not using the splitter?
    Jan 2016
    Newcastle
    Vehicle : Vectra c
    Trim : Sri
    Engine : 1.8
    Year : 55
    Quote Originally Posted by Sindy View Post
    Thereís no possible way to connect to Airel direct short of chopping the cable and changing the end
    Jan 2016
    Newcastle
    Vehicle : Vectra c
    Trim : Sri
    Engine : 1.8
    Year : 55
    This is what I bought I’m thinking probably cheap rubbings https://rover.ebay.com/rover/0/0/0?m...2F223540284900
    Dec 2015
    Yorks
    Trim : Mohican
    Engine : Z20NET
    Just so I can get my head round this, you have one aerial on caravan that you're trying to split DAB and TV from?
    When you say you can get DAB on the TV, do you mean the radio stations over freeview?
    If so I'm thinking the caravan aerial isn't DAB compatible - i.e. not capable of receiving DAB signals - it's normally a dedicated aerial for that tuned to the correct wavelength spectrum.
    Jan 2016
    Newcastle
    Vehicle : Vectra c
    Trim : Sri
    Engine : 1.8
    Year : 55
    the caravan has a stutus 570 Airel and matching booster/splitter. It has 3 or 4 tv ports and one radio port.
    so the Airel can receive digital tv analog radio and dab radio.
    a quick google search will confirm this.
    its a brand new Airel so that should be fine. What you don’t get with the Airel is the splitter like the type I’ve put the link up in the other post. So I’m not sure if I’ve bought cheap rubbish splitter or if I need to buy something to further split the signal or could it be something else
    Dec 2015
    Yorks
    Trim : Mohican
    Engine : Z20NET
    Ah got you - missing bit of the puzzle is how you've connected the splitter, that shows a normal car aerial connector input but your booster has F type connectors on it - have you made a lead up for that bit?
    if your radio has an SMB connector for the DAB side I'd either solder up or buy a plain F type to SMB cable to test properly without splitting it.
    Jan 2016
    Newcastle
    Vehicle : Vectra c
    Trim : Sri
    Engine : 1.8
    Year : 55
    Comes out the booster with f type then runs through van then plugs into radio with a normal car radio end hence why I bought that splitter. What and make a fly lead ? Would have to be quite long to reach from Airel to radio
    Dec 2015
    Yorks
    Trim : Mohican
    Engine : Z20NET
    Got it - does the FM side work then plugged in to the radio without the splitter?
    Jan 2016
    Newcastle
    Vehicle : Vectra c
    Trim : Sri
    Engine : 1.8
    Year : 55
    I’ve not tried it without splitter but the fm side seems to work with the splitter
  1. aftermarket radio and dab radio
    By pauluk49 in forum Electrical & ICE (including SatNav)
    Last Post: 29th April 2019, 14:17
  2. radio and hid's
    By Al 22 dti in forum Electrical & ICE (including SatNav)
    Last Post: 5th August 2011, 13:10
  3. Radio 1
    By vec-cal in forum Electrical & ICE (including SatNav)
    Last Post: 31st August 2010, 00:17
  4. Radio Help
    By swickle09 in forum Electrical & ICE (including SatNav)
    Last Post: 15th February 2010, 17:02
  5. F1 on radio help
    By shan in forum General Chat
    Last Post: 20th October 2007, 13:27
